Page 24 of 139 FirstFirst ... 1422232425263474124 ... LastLast
Results 231 to 240 of 1381
Thread: Golf 118 TSI Engine Failures and Service Campaign 24S4
  1. #231
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by team_v View Post
    Would the aftermarket tune prevent the engine failures as it has already been remapped for different variables?
    Depends if the remap variables are in the regime that is effected, I would think. It is quite possible that they are not. It is possible that the VW fix changes stuff that an after market tune does not even deal with.
    Or would you have to get the dealer remap and then re-flash the ecu with the aftermarket tune again?
    Yes, thats the path I am intending to take.
  2. #232
    Adelaide hills, SA
    So what happens to people who have got an aftermarket ECU tune?
    would you have to get the dealer remap and then re-flash the ECU with the aftermarket tune again?
    IMO it is quite possible that aftermarket remap, chip or any mods could undo what VW attempted to fix. But that's only my opinion.
  3. #233
    Point Cook, Vic
    You would need to know exactly what the VW retune does to know for sure. You would think that most tuning companies would be looking at it pretty closely to make sure if they need to revise their maps they do.
    Have their been any cars with aftermarket tunes suffer similar engine failures?
    FOLLOW US ON FACEBOOK
  4. #234
    Feb 2009
    Sydney, Australia
    So what happens to pepople who have got an aftermarket ecu tune?
    Guy_H had this to say in relation to your question over here
    Already had some APR cars that have had the factory reflash done, no problem to re do the APR with the updated VW specific code once you have had the VW work done!
  5. #235
    Aug 2009
    Melbourne, Vic
    Which all ties in with the VW "fix" modifying something unrelated to what the tuners tune. Have just got myself an 10 minute Pre-fix log of numerous parameters. Cold start through to near max boost. Will be interesting to compare it with an afterwards log to see what, if any, changes are visible. I still have a hunch the issue is not where everyone around here is looking, and will report back if it turns out to be the case.
  6. #236
    Sep 2009
    Quakers Hill, NSW
    Quote Originally Posted by logger View Post
    Good Point, although you'd think they would only contact that batch of owners if that was the casel.. But might as well add it.
    A few questions for those who had TSI engine failures:
    How Many KMs?
    Do you mainly do a lot of short trips?
    Do you mainly do fewer longer trips?
    Do you alway drive in a gentle manner?
    Do you flog the car and give it a bit of a hiding from time to time?
    Do you only use 98Ron fuel?
    What is your car build date?
    Perhaps it may be of interest to get these questions answered by those who haven't had a problem, like me. Not particularly scientific, but a control group of sorts. The Golf is mainly driven by my wife, whose most common workplace is about 4 kms from our place. We are in the northwestern suburbs of Sydney ( it was 1 degree outside this morning) so it gets cold starts. It goes in next Wednesday to be reprogrammed.
    How Many KMs? 9000
    Do you mainly do a lot of short trips? Yes
    Do you mainly do fewer longer trips? No
    Do you alway drive in a gentle manner? No
    Do you flog the car and give it a bit of a hiding from time to time? Yes
    Do you only use 98Ron fuel? Yes
    What is your car build date? 07/09
    2009 118 TSI
    1980 Bedford van
    2015 Hyundai i30 SR
  7. #237
    Adelaide hills, SA
    Since the fault happen in such a short time from new, I would also ask the question about how the engine was run in? But as logger said, who knows what causes it?
  8. #238
    Adelaide hills, SA
    Quote Originally Posted by Tim View Post
    I 100% agree with that and until they find out for sure what cause the pistons cracking, I wouldn't be very comfortable with retuning or using other than VW tune, because if someone would get the same problem again within the warranty, they (VW) could blame everything on the aftermarket tune and wipe their hands clean.
  9. #239
    Point Cook, Vic
    its all speculation at the minute. Be good to hear some accurate info to base opinions on.
  10. #240
    Adelaide hills, SA
    Yep, my speculation would be that it is a bad badge of pistons or pistons not suitable for application and VW fix (at least for now) is to downtune the engine a bit.
