Page 19 of 139 FirstFirst ... 917181920212969119 ... LastLast
Results 181 to 190 of 1381
Thread: Golf 118 TSI Engine Failures and Service Campaign 24S4
  1. #181
    Sep 2009
    Western Australia
    What a passionate argument!
    Had I actually used 95 RON I would probably be kicking myself right now. BUT I DIDN'T.
    So whatever problem my engine had, it's not 95 RON related.
    I always used the best fuel I could find - ALWAYS 98 RON. And usually BP Ultimate.
    And if it's an issue with the useless Aussie fuel in general, then people using 95 RON will also have problems.
    Mk6 VW Golf TSI DSG
  2. #182
    Mar 2010
    Omnipresent
    Quote Originally Posted by Maverick View Post
    Find me a model of car that has left the production line without any design flaws or faults?
    Volkswagen identified an issue with a production range that could be due to many many factors, they have released a fix for this fault, they are fixing cars under warranty that fail and are being proactive in addressing this issue. There was no recall issued, a recall is different to a field campaign.
    A prudent owner that understands fuel would not run an engine on a minimum requirement fuel when for no more outlay they can get a premium fuel that gives their engine more room if there is a problem IMO.
    Sure and does this mean leaving the tyres on the minimum inflation levels, replacing the tyres with cheap tyres that meet the requirements despite poor performance, using a fuel that is borderline if you get a bad batch and so forth. A careful owner would not do any of these but would realise that there are benefits in having increased tyre pressures, using higher performance tyres, using a better performing fuel (especially given the FSI) and so forth.
    Volkswagen have addressed the issue and will look after those that have failures. As I said it's the end of the story as far as customers are concerned, they're not going to find out any more information from the dealer because it's unlikely Volkswagen has gone into detail with them.
    Staggeringly, you don't get the issue I have Maverick, and I don't have the energy to explain it all again.
    Time to get ready for the Budget. Can't wait to see all ALP heads nodding in unison behind Wayne Swan ... the intellectual giant and economic wizard that he is!
    God help us all.
    118TSI, DSG, Candy White, Sunroof, RCD510, Dynaudio, USB + iPod cable, Reversing Camera, Adaptive Chassis Control, Prem. Bluetooth, Fogs, Tint and Mats.
  3. #183
    Dec 2007
    Quote Originally Posted by BBP View Post
    God help us all.
    And you objected when you thought Maverick was getting personal, but it's OK for you to get personal about a leader elected by the majority in our democratic system.
    Government would be better if using a higher quality parliament, but the people have mandated the use of a parliament meeting the minimum standard.
    In reply to the earlier question about whether the engine will be satisfactory long term if the piston is replaced rather than the whole engine, the answer would be yes. A hairline piston crack will not usually damage the bore in an engine, so a new piston and rings can be installed. I expect VW will replace the entire set of pistons, rings, and big end bearings, and your engine will last as long as a new crated engine would.
    However, if there is scoring the story could be different - I don't know if these blocks can be re-bored at all. If yes, then all would be OK with a set of oversized pistons. If no, clearly the block would need replacing.
    2008 Blue Graphite GTI DSG with Latte leather. SOLD 4/9/2024
    2023 T-ROC R - Sunroof, Black Pack, Beats Audio
  4. #184
    Dec 2008
    Perth
    Why the F are you talking politics?
    I have to agree with BBP, no one should have to worry about what grade of fuel they choose, as long as it is equal to or better than the minimum. Having said that, I always use 98 RON.
    Also, following on from cameronp about different brands of fuel, I know in Perth and Adelaide, there is only 1 refinery each, so I would assume the sulphur content would be exactly the same for each brand in those cities. Maybe the larger cities have more than 1 refinery and there may be some subtle differences between them. I would not rely on anecdotal evidence from users and tout 1 brand over any other.
    MY14.5 VW Polo 81tsi Comfortline - Candy White - Comfort Pack
  5. #185
    Mar 2010
    Omnipresent
    Quote Originally Posted by gerhard View Post
    Nice one. I like it !
  6. #186
    Aug 2009
    When I bought my car the min recommendation for fuel in the 118TSI was 98RON. VW revised it not long after and changed the minimum to 95RON.
    see here: http://www.caradvice.com.au/38849/ne...-ron-unleaded/
    Personally, I don't use anything less than 98.
    The article states that they took into account the Aussie fuel standards and felt that 95 was appropriate, but surely there was a reason it was originally 98. At the time I thought it was to make the car more marketable because I'd seen complaints that the car required 98 and made it seem more expensive to run.
    Recommendation or not, I don't want to take any chances and want to use the best fuel I can put in there
    2009 VW Golf 118TSI | United Grey | DSG | Sports Pack + ACC | RCD510
  7. #187
    Aug 2009
    Back on the topic of engines blowing up, I've got mine booked in for next week to get a couple of things looked at. They said they'll plug it in when I take it in to see if it needs the update after I asked about it.
    It's a bit rough when cold but seems to warm up ok. Also a few times there's been a clicking/grinding noise from the back followed by a puff of smoke.
    So hopefully my car is not about to go down the same route as others on here... eek
  8. #188
    Apr 2010
    Nedlands, WA
    Interestingly, when the 1.4 twincharger was first released (2007), Europe was on the Euro4 fuel and emissions standards, which allow the same maximum sulfur content (50ppm) as in current Australian 95RON and 98RON. So you would think that there is nothing fundamentally stopping the engine from working with Australian fuel. I guess that doesn't rule out the ECU having been misprogrammed for it, though.
    Am I right in understanding that the owner's manual for the 118TSI recommends using 98RON fuel, with 95RON being the minimum (and resulting in reduced power output)? In that case, I reckon both BBP and Maverick are right: you would have to be pretty daft to use 95 regularly, but if doing so results in engine damage, Volkswagen have some serious explaining to do.
    Golf 118 TSI DSG, white with sports pack.
  9. #189
    Jan 2010
    State of Denial
    Quote Originally Posted by Flighter View Post
    If the block is alloy, then I would expect the cylinders to have liners, so perhaps these are replaceable.
    The 1.4 has a graphite cast iron block with an open deck design - no liners.
    Also we're making an assumption here that it is fuel related - it is possible that they made an error in the ECU calibration when doing the SW variant for the Australian market. It wouldn't be the first time a product was sold with a software error!
  10. #190
    Feb 2010
    Canberra
    Aren't they detuning the Golf R for Australian Conditions ? Couldn't it be possible they "should" have detuned the TSI for OZ as well. Higher temps, lower fuels etc etc etc.
    Ex- 2010 Golf GTI
    Ex - 2015 Skoda Yeti
    Soon - 2016 Tiguan
