I'm with BBP, the point is if the engines needed 98 then it is VW's responsibility not to tout 95 RON as a minimum.
Also the argument about sulphur content is purely speculative at this stage as AFAIK has not been confirmed by VW as the reason for the reflash.
Interesting discussions, but I have never, ever put anything but 98 RON in my car...
...and wherever possible I do use BP Ultimate. My local Petrol station is a BP.
Mk6 VW Golf TSI DSG
The issue wasn't the cylinder itself, it was the piston (specifically the head of the piston in cylinder 2) that had a small crack.
I really don't mind a repair vs. an engine replacement as long as it's done properly and doesn't cause me issues somewhere down the line. Unfortunately I'm not sure I believe that this will happen.
Mk6 VW Golf TSI DSG
1. So "It is the point if you knew anything about fuel" is not personal. Ok then ....
2. A problem leading to a recall is not the "end of the story". Saying something does not make it so Maverick. If the fuel grade is the issue (and again that is speculation on the part of us all) then God knows how many customers are going to have problems, engine failures, inconvenience etc. The story is whether those customers should have had the problem in the first place.
3. You guys mentioned the work around solution of 98RON, not me. I was just pointing out the irrelevance of that possible solution to the issue at hand.
4. "Caring for the car and understanding fuel" ... do I need to say it again? That's not the point. A careful owner should have to do no more than what the manufacturer suggests. No owner should have to "understand fuel" - VW tells them what to use !
118TSI, DSG, Candy White, Sunroof, RCD510, Dynaudio, USB + iPod cable, Reversing Camera, Adaptive Chassis Control, Prem. Bluetooth, Fogs, Tint and Mats.
Find me a model of car that has left the production line without any design flaws or faults?
Volkswagen identified an issue with a production range that could be due to many many factors, they have released a fix for this fault, they are fixing cars under warranty that fail and are being proactive in addressing this issue. There was no recall issued, a recall is different to a field campaign.
A prudent owner that understands fuel would not run an engine on a minimum requirement fuel when for no more outlay they can get a premium fuel that gives their engine more room if there is a problem IMO.3. You guys mentioned the work around solution of 98RON, not me. I was just pointing out the irrelevance of that possible solution to the issue at hand.
Sure and does this mean leaving the tyres on the minimum inflation levels, replacing the tyres with cheap tyres that meet the requirements despite poor performance, using a fuel that is borderline if you get a bad batch and so forth. A careful owner would not do any of these but would realise that there are benefits in having increased tyre pressures, using higher performance tyres, using a better performing fuel (especially given the FSI) and so forth.4. "Caring for the car and understanding fuel" ... do I need to say it again? That's not the point. A careful owner should have to do no more than what the manufacturer suggests. No owner should have to "understand fuel" - VW tells them what to use !
Volkswagen have addressed the issue and will look after those that have failures. As I said it's the end of the story as far as customers are concerned, they're not going to find out any more information from the dealer because it's unlikely Volkswagen has gone into detail with them.
website: www.my-gti.com
tornado red GTI MkVI, 5dr, DSG, Sat Nav, RVC, MDI.
Red Honda Fireblade Red Cooper S (SOLD)
