Page 8 of 139 FirstFirst ... 6789101858108 ... LastLast
Results 71 to 80 of 1381
Thread: Golf 118 TSI Engine Failures and Service Campaign 24S4
  1. #71
    Dec 2008
    Sydney/Canberra
    ^^ What he said.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  2. #72
    Feb 2009
    No probs at all with mine. Works like a charm.. I have never used anything but 98 in it, and lately only fill up with BP from newer petrol stations.. But then i don't trash the crap out of my car every time i drive it either!! and never give it any boot until the engine is warm.. A lot easier to be gentle to the engine in a manual.
    |Golf Mk VI 118TSI|Manual|Pearl Black|Sports Pack|Sunroof|F & R Parking Sensors|Park Assist|RVC|Alarm|RNS-510|VW Premium Bluetooth|MDI| http://www.hoodiaslimming.com.au - 100% Pure, 100% Organic
  3. #73
    melbourne
    Quote Originally Posted by guliver_twist View Post
    tell me about it! the ability to control revs is huge for me in my polo tdi which takes 10kms to warm up.
  4. #74
    Jul 2009
    With the point regarding the engine running overly lean, would you think that an aftermarket tune, let's just say an APR chip for arguments sake, would fix this issue? I would assume that APR when doing their tuning would have modified the air fuel ratios throughout the rev range, perhaps in fact making it run a little richer due to increased boost?
    Anybody have any solid info on this?
  5. #75
    Feb 2009
    Sydney, Australia
    I think that only someone like Guy H would probably be able to speak to that.
  6. #76
    Closet Diesel Owners Club President.
    My car has been faultless too... 1.4 twincharger early GT motor.
    I think there has been some re-engineering for profit "RFP" on the newer 118 TSI's hence the squeek and other issues.
    I think the early GT, GT sport 1.4's are the strongest as they don't squeak and have had no failures as far as I am aware.
    The first oxy sensor controls fuel trim to achieve 14-14.7:1 and the second only checks for temperatures and cat efficiency. So you only need the first one to fail for things to go up **** creek as far as the documentation I have on the engine goes.
    *Disclaimer - Don't rely on me, seek your own professional advice. Audi R8 E-tron. 230kw 4500nm! (not a typo).
    Economy at 100kph =5.5L
  7. #77
    Sep 2009
    Quakers Hill, NSW
    Quote Originally Posted by POLARBEAR666 View Post
    My wife's 118TSI has also been fault free.
    Surely a Lambda sensor failure would throw a fault code on the MFD and put the ECU into limp home mode before there was any damage. Also, I would have thought an excessively lean mixture would burn valves before it softened a piston sufficiently .
    I would think a ring failure due to insufficient end gap would be more likely with piston failure secondary to ring failure.
    I will be watching this thread with interest.
    2009 118 TSI
    1980 Bedford van
    2015 Hyundai i30 SR
  8. #78
    Oct 2009
    Sydney, NSW.
    Post
    What about opening up the oil filter top using a cutting tool like they use in general aircraft maintenace and then seeing the metal shaving and bits etc stuck on the filtering paper itself?
    When you see metal bits on the filtering paper then you know the engine is up the creek.
    Last edited by Corey_R; 22-03-2010 at 04:52 PM. Reason: Removal of quote as per request
    To most people, the sky is the limit. To those who love aviation, the sky is home.
  9. #79
    Nov 2007
    Quote Originally Posted by coreying View Post
    While Guy has a lot of experience with VAG engines, it'd be foolish to suggest he has a monopoly on said knowledge...
    Last edited by Corey_R; 22-03-2010 at 05:00 PM. Reason: Removal of quote as per request
  10. #80
    Nov 2009
    SEQLD
    So are they going to do a recall on these engines or what's the go? Surely the new 118TSI Golfs on order and coming over in the next few months would have had the problems fixed?
    MY20 Golf GTI TCR
    MY20.5 LR Defender P400 HSE
