Hi All,
My daughters 2010 golf 118tsi (70000 klms) in v good nick, (SURPRISE) blew multiple pistons the other day, (3 cylinders v poor compression) my mechanic has diagnosed cracked pistons via oil sealing the cylinder then compression testing (not bent valves as compression stays up with oil seal)
In light of a 10 year old, dealer serviced vehicle, does any one think it is worth;
a; pursuing with VWA or local VW dealer for assistance as a matter of principle as per transporters comments below
b; going to someone like volkewerke to get a rebuild with decent pistons and warranty ($7k) given the car is worth 10k but hard to replace for similar money
c; selling the thing, as is for bugger all and getting the daughter a corolla or mazda 3 as per mechanics advice
thanks for any help
Pretty much this and pray to all the deities at once (and let us know the outcome of course). August last year was the last confirmed documented case (in this thread) of VWA coming to the party so it's worth a shot.
Unfortunately, there isn't a lot of good ways out of this otherwise. A drop-in replacement can be cheaper than a rebuild if done on the cheap, but it's not exactly a small job so unless it's mates rates or done yourself there may not be a lot in it, you also have the risk of an unknown engine.
Rebuilding is best, but also very time consuming, again unless you can get mates rates on the labour it's going to suck.
Plan C would be an engine transplant to something that's not the twincharged motor, but that's potentially more complicated but does at least leave you with an engine that's far less likely to fail again.... except you then have a sort of Frankenstein vehicle which would likely be harder to move on later. When my engine went pop I was 100% in going down the GTI transplant route (which needs an engine and gearbox), but only because it's in a Cabriolet, if it was just a normal hatch it would be a real toss up between just writing it off and buying something else...
On the buying something else note, assuming you otherwise like the Golf, there are currently 14 non 118TSI Golfs from 2010/11 for sale on car sales for $7k or less. You could buy one of those, cherry pick all the good/upgraded parts and swap them into the running one eg nicer seats, chrome bits then try to sell off the broken one as parts. It's not a great option, it's time consuming and painful, but you'd likely recover at least some of the cost.
Hi apewearingclothes
Same issue happened to my daugthers 2010 118TSI in Oct last year. I took it to a VW dealer in Adelaide and was advised that it would be unlikely that VW would provide a goodwill repair.
VW would not commit to a goodwill repair unless I agreed to pay approx. $1,000 to get it fully diagnosed. I was concerned that I could outlay $1,000 and then have VWA refuse to provide any assistance.
I took my time and spoke to a number of independant VW mechanics and basically was told that it was 99.9% certain to be a cracked pistion in cylinder 3.
The dealer rang me in early Dec and I rolled the dice and indicated I would pay for the full diagnosis. The diagnosis confirmed a cracked piston in cylinder 3 but no bore damage. The dealer put forward a request for a goodwill repair to VWA and much to my surprise I was informed that VWA agreed to do the goodwill repair at no cost whatsoever to me. All up the pistons replaced plus the timing chain and tensioner.
We got the car back at the end of Dec and it is running perfectly and we are very happy with the repair.
In this instance VWA came to the party and covered the entire cost of the repair. I can only say thank you very much to VWA. They have received a lot of bad press in the past but I can only speak highly of them.
All the best. Good luck. One tip. Get the goodwill repair request submitted early in the month.
Hope that helps.
No did not have to pay anything. $0
VWA covered entire cost of the diagnosis and repair. All up I believe it was about $8k.
So many of these sale too going cheaper than other engines
only people in the know steering away from them
I would have thought VW would have been on to this
