+1,
...and not every golf6 1.4TSI twin charge fails. I see quite a few that passed well over 100,000km now.
+1,
Of course, as pointed out by Transporter, not every 1.4 twincharger fails but there is a clear pattern of failure. I guess it's all about how much of a punter you are. I would ask myself these questions before purchasing
1) Do I accept that this engine model is prone to failure?
2) Do I accept that that in the event of failure, VWA may or may not be prepared to cover the cost and if not, it will cost something like 50-60% of the car's value to repair?
3) Do I accept that in the event of as failure I will need to negotiate the (often lengthy) VWA process for VWA to accept liability?
4) In the event of a failure, am I prepared for the significant amount of time it will take for repairs to be effected? (In some cases in this thread it has taken months)
If the answer is yes to all of the above, go for it.
Happy punting!
George
06 Jetta 2.0TFSI Killed by a Lexus!
09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
14 EOS 2.0 TSI has arrived!
The risk of engine failure has been priced into the market. You can get a lot of car for $7,000 today. Even if you had to pay $3,000 for a new engine you're still getting good value. The Mk VI design is ageing well too IMO.
The early models show a higher failure rate before a software update was supposed to "fix" the problem (general consensus seems to be that they updated the fuel map to combat lean running). The '09 - '10 ones were all the same. The fix was in '11 and the failure rate dropped, but then there are ones like mine (which were an '11) which still failed. They changed the pistons in a revision of the engine (CAVD vs the later CTTH) which made it better again. But if you're looking at an '09 you're in the sweet spot for failure.
Reapir is a pain, is time consuming and doesn't happen when you want. Even if you factor in the cost (and I think $3k is a little low) it's still a gamble. Honestly, there islots of MkVI GTI's listed at around $15k, shave off a little after negotitation and you're going to buy a better vehicle with less liklihood of failure. To be fair, It's probably double what you're going to pay for the 118TSI which could just be unaffordable.
Plan B: 103TDI. At about $10k or so it sits nicely in the middle and besides the whole dieselgate thing they are great cars.
It's very hard to recommend the 118TSI, while it really is a great car to drive, well featured (it was the top spec non GTI model), there is a just a huge risk involved in that engine. If you're aware of all that and are still willing to buy one, like I said, they really are a great car with a great engine (you know... other than the explody bits).
Gerald Slaven VW in Belconnen will do authorized warranty work as well. My work colleague has recently traded in an Amarok, he did not have good experiences with Lennock doing warranty repairs (took weeks and no communication unless you chased them for an update).
1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
1996 Vento GL (white) - RIP
@MotleyLemon.... I am in the process of having my 2009 118TSI Comfortline fixed by VWA on goodwill. All in all, my local dealership have been very pleasant to deal with, but as others have said it is extremely timely and a lot of not needed stress.
The car has been with them now for going on 9weeks. In this time they have found a cracked piston in cylinder 1. In this part of the repair (which took 6 weeks), they replaced, oil breather pipe, R&R piping, belt, wiring, turbo, timing case and chain, oil and coolant filters. The cylinder was removed, decarbonised and resealed and replaced with new bolts, gaskets. They then took it for a test drive and discovered the clutch in the automatic DSG was worn. Clutch was replaced, as well as battery, starter, drive shafts (took 2 weeks). I picked the car up after all of this (8 weeks), and it was still rough idling. I took it back to the local dealership and they found that one of the injectors needed replacing. Today (9 weeks after I dropped it off), they called and said even after replacing the misfiring injector, it is still running rough....
Although this has all been covered under VWA goodwill, and I have been provided with a loan car free of charge, this whole process has been far less than average. If you can avoid it by buying a different car (or even a 118TSI that’s already had the engine overhaul), you would be saving yourself a lot of stress and time. I currently have my golf advertised on Carsales (QLD) for $12k and even with all these massive engine maintenance and gear box repairs, I still have had no enquirers. Maybe something to think about. Goodluck 👍
You won't get $12k for a 2009 as long as your pink dot points to the ground.
