Page 83 of 139 FirstFirst ... 3373818283848593133 ... LastLast
Results 821 to 830 of 1381
Thread: Golf 118 TSI Engine Failures and Service Campaign 24S4
  1. #821
    Feb 2016
    No worries at all - I don't mind the 7 spd DSG too much... Getting used of it now.
    But if a tune will mean i get 60k kms out of it... it will be worth the dollars.... and some extra poke would be good.
    I have read that the 7 spd DSG doesn't like any-more torque than 245nm ?
  2. #822
    Oct 2014
    Quote Originally Posted by JS118tsi View Post
    Be careful. I started out telling myself I'd just get the 1.4 twincharger stage 1 tune. Fast forward 2 years and i'm sitting in traffic to pick up a Golf R intercooler, have 3 quotes on aftermarket downpipes and keep looking at lightweight rims...
    See here for the DSG upgrade from Harding Performance.
    DQ 200
    GuyH on the forums can tell you if and how to get it outside of Brisvegas.
  3. #823
    Just remember that the stage 1 tune is mainly to fix up the fuel trim issues with the car running too lean on start-up and in cold weather. VW does this to try and heat up the cats to operating temps faster so that they catch all those nasty emissions. The downside is that it can significantly shorten the life of the engine. Tuning the car can fix this to a large extent.
    The DSG upgrade is really to lock the clutches up quicker and to eliminate a lot of the slipping that occurs in the stock program at low speed. You can imagine that as the clutches slip this causes quite a bit of heat and in slow stop/start traffic this effectively fries the clutches. To make matters worse VW decided to run the DQ200 as a "dry" clutch so there's a lot less cooling that happens in a "wet" DQ250 6 speed.
    Trinidad and Tobago
    Quote Originally Posted by Mk R View Post
    DQ 200
    LOL it is very addictive.
    Have you gotten lowering springs? If not then those might be worth your while looking into before the lightweight wheels.
  5. #825
    Everyone in this thread seems to be the orignal owner. Any reports of goodwill for second or third owners?
  6. #826
    Oct 2014
    Quote Originally Posted by Rawcpoppa View Post
    Yeah, got the VWR sport springs and adjustable Whiteline sway bars set to medium. Sits low but still looks stock unless it's next to another golf...
  7. #827
    Dec 2006
    Kilsyth, VIC
    Part of me wants a little more lows on my car...
    But then I sort of like not having all the clearance issues I had last time around
    Then there is question of which coils... or bags...
  8. #828
    Feb 2016
    Just checked my Golf... it has the 24s4 recall sticker... is this good? Was done in 2010.....
  9. #829
    Feb 2016
    So it seems the 24S4 is the ECU upgrade/retune/software.... This makes me a bit less stressed now.... also has the DSG Mechatronics recall 3xxx (or something)
    Im guessing, i can relax a little bit now? Besides the clutch packs wearing out?
    Thanks for the help everyone...
  10. #830
    Trinidad and Tobago
    Yup you can relax a bit. I do worry about pistons made before 2012 though.
