Given the post below (from another thread) I'd say the problem is inherent in the design of the piston and rings and it would a really major revision to fix it properly. It's talking about the higher output version fitted to the 6R Polo GTi but that's basically a slightly tuned up version of the 118 twincharger (the comparison CAVD engine is the twincharger used in the Mk 5 Golf GT frpm which the 118 twincharger was developed)
Originally Posted by
Varnak
My friend for me is dead simple what is going on here. The twincharger engine was, in euro4 format, an excellent unit with the only criticism from rivals being its high emissions. Here in Europe emissions are of high importance since we are getting taxed based on them. Also note that the last cavd engine could not go to production (being marginally euro 5 on the scirocco).
60 per cent of the mechanical losses of internal combustion engines are due to cylinder piston ring contact. What to you do to reduce emissions ? You reduce tension between the two. Well in theory that produced the perfect engine with 138grams/ almost 200 hp stock and consumption only up by 10% when compared with cavd units ( still very sensible). In practice though they failed to accommodate for the rapid boost build up of the compressor with the new piston/piston rings setup, thus the screw up.
Can they sort the problem? Of course it is dead simple: just change the piston and piston rings back to CAVD specs, there! Problem sorted.
Can they solve the problem and meet emissions standards as advertised? NOT A CHANCE. Thus they are pretending nothing is wrong as a strategic decision. The VAG group would not admit to such a major engineering screw up. They will happily change as many engines as you want while in warranty until they produce the mk6 polo/mk6 ibiza with a new engine line up.
This is accordance to their first attempted fix of installing thicker piston rings ( i.e higher tension) but obviously that was not well thought out either, or not well executed by dealers.
So if you like the car and want to keep it, find a good local garage buy 4 piston and piston ring sets from a CAVD engine and off you go. A lot of guys down here have done just that and solved their consumption issues. Some even tried aftermarket piston ring sets and that solved the problem. Of course you need to re-hone the cylinder walls before installation.
adhock
Is it time to start a thread devoted solely to documenting the number of 118TSI engine failures?
I see numbers round 500 on the threads here, and comments such as 'Dropping like flies', but not hard numbers. So, is a thread listing Year/Month build, delivery date, kilometers driven, date of failure, dealer, VW response, (what have I missed) worth while? The mutterings about Class Actions need this sort of stats, I'd think.
An engine failure register thread could be a good idea as you wouldn't get the clutter of discussion about DSG failures and denials from VAG fans - see the diesel section for how they did one for the 2.0l 125kW PD engines
Resident grumpy old fart
