Page 57 of 139 FirstFirst ... 747555657585967107 ... LastLast
Results 561 to 570 of 1381
Thread: Golf 118 TSI Engine Failures and Service Campaign 24S4
  1. #561
    Apr 2010
    Faults in the first (engine) module
  2. #562
    Jun 2011
    Here's my log. Should I be concerned about a one-off?
    Address 01: Engine (CAV) Labels: 03C-906-027-CAV.clb
    Part No SW: 03C 906 027 BA HW: 03C 906 027 F
    Component: MED17.5.5 G 5860
    Revision: L1H08--- Serial number:
    Coding: 0000077
    Shop #: WSC 01016 959 86335
    VCID: 61CDA1B7C1D9
    2 Faults Found:
    000768 - Random/Multiple Cylinder Misfire Detected
    P0300 - 000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 46065 km
    Time Indication: 0
    Date: 2101.14.16
    Time: 11:09:04
    Freeze Frame:
    RPM: 683 /min
    Load: 16.9 %
    Speed: 0.0 km/h
    Temperature: 72.0°C
    Temperature: 22.0°C
    Absolute Pres.: 1010.0 mbar
    Voltage: 14.224 V
    000771 - Cylinder 3: Misfire Detected
    P0303 - 000 - - - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 46065 km
    Time Indication: 0
    Date: 2101.14.16
    Time: 11:09:04
    Freeze Frame:
    RPM: 683 /min
    Load: 16.9 %
    Speed: 0.0 km/h
    Temperature: 72.0°C
    Temperature: 22.0°C
    Voltage: 14.224 V
    Readiness: 0000 0000
    MY09 118TSI - SOLD
  3. #563
    Apr 2010
    I'd be mentioning the misfire to the dealer. Don't clear the fault or they'll have nothing to see.
  4. #564
    Jan 2010
    UK Cheshire
    When was the misfire - when warming up or at running temperature?
    How long after cold start?
    How dry is the humidity and at what outside air temperature (rough figures)?
    VW SCIROCCO 1.4TSI - DSG (MY2010) UK, East Cheshire.
    Build Complete October Wk43/09, Driving 4th November - Wk44/09. Sorted !
  5. #565
    Jun 2011
    Quote Originally Posted by RW1 View Post
    Car had only been driven a couple of km from cold start. Not yet fully warmed up. About 20 degrees, 60%.
    MY09 118TSI - SOLD
  6. #566
    Jan 2010
    UK Cheshire
    I suspect you have the cold start misfire problem. Its the one not covered by the first issue of 24s4 which you have loaded, ie. map 5860 in your Address 01 dump.
    Two options:
    1) Go to the dealers and tell them the misfire logged is during warm-up. Your ECU 5860 map does not cover a certain set of conditions during warm-up where a known misfire can occur. The latest map 9660 is the rectification for this on DSG (was partly rectified with map 8913 which superceded 5860). They had to further tweek the map on the DSG only to 9660. (Manual gearbox ECUs need latest map 1676 or previous 0888 loaded to cover this misfire.)
    The reason the misfire occurs is because there is a slight reduction in fuelling at the mid warm-up period ahead of the engine being ready for it under certain warm air conditions. So effectively, the mixture goes too weak for the running conditions momentarily as it passes 35'C -ish coolant temp. Lasts about 10 to 20 seconds depending on how idling/driving. Ask the dealer to look at TPI-2023712/3.
    It will not help that the spark plugs fitted will be above 0.80mm. So consider replacing/adjusting them as below. This is not part of the TPI, so is not warranty covered.
    2) Alternatively, shortening the spark plug gap to 0.70mm - 0.75mm overcomes the problem entirely. Doing this also leads to a much smoother and calmer running engine. The nearest the dealer can do is fit the new 1.4TSI 118Kw revised NGK plug 03C 905 601A VW have introduced. (NGK - PZFR6R8EG) which has a plug gap of 0.80mm. This is because dealers do not gap plugs on fitting.
    IMO the gap of 0.80mm doesn't quite go far enough but is a step in the right direction for it to stand alone without the revised ECU map if you cannot get the gap adjusted to 0.70mm. This plug change is not covered in the TPI referenced above. Been running this reduced gap for the last two years without any further warm-up problems and still run map 5860. Had very bad conditions for it from April to July this year. Not a murmur out of the engine nor did it happen after I did the adjustments in late 2010. I initially ran 0.75mm plug gap late 2010/2011, but now run 0.70mm since late 2011.
    Left wheel spin has also gone when setting off, even in the wet. Front tyre wear has been reduced considerably. And an added benefit is the 7spd DSG works better because the engine output torque is smoother. DSG is holds gears better rather than change under certain town traffic driving. ie. used to use D4, now it will use D6 very happily.
  7. #567
    Jun 2011
    Wow - detailed analysis! I'll try the plugs. Cheers.
    MY09 118TSI - SOLD
  8. #568
    Sep 2011
    Sydney Northern Beaches
    Hi RW1,
    I have read about your change in the gap for the sparkplugs before. Is is only applicable to the 118TSI as I have some rough idle / misfire at startup (the first 10-15 seconds when the engine is reving a bit higher) and the eingine is also pinging under load going uphill in 3rd
    The car has been to the shop 3 times but they can't find a fault. So I am thinking this would be a good start to play around with the spark plugs or a revised version if available for the 90TSI .
    Thanks.
    regu
  9. #569
    Jan 2010
    UK Cheshire
    Quote Originally Posted by hentaiboy View Post
    If you are going to do it yourself, be warned the coil packs are in tight. Not to be levered out with a screw driver as the coil electronics can be damaged as a lot of force is needed, even if previously removed. The tool is T10094A - VW Coil Pack Puller Tool (for 1.4TSI Coil Packs) – £34.80 inc. VAT in the UK. The local VW Parts Dept. will order it cos you can provide the part number without them searching.
    Alternatively, make a multi-wire hand wrap around the coil pack head where the VW tool slots in and use that to distriute the pulling load as you pull the pack. Once initially released off the plug, disconnect the coil pack connector. Then continue to raise and remove the coil pack.
    No1 cylinder (right side - alternator end) needs the oil breather pipe moving out of the way by releasing the two small Torx T30 bolts (torque - 10Nm). The pipe will still need wedging out of the way or held by an assistant while you access and pull the coil pack. Plugs are 25Nm torque tightening.
    And try and remove and transfer as much of the grease from the old plugs to the new. Its expensive to buy, the part number is G052 141 A2 20g tube at about £20 in the UK. Needs about 2g per coil pack/spark plug to do the job properly.
    Quote Originally Posted by regu View Post
    Hi RW1,
    Thanks.
    regu
    Hmmm going a bit off topic as this is not 24s4 related. Plugs don't sound like the solution to your problem. I need you to put up an up to date VCDS Autoscan for Address 01 engine ECU (in full) like hentaiboy's above to understand where the garage has got to with the ECU. If you put the above query and the VCDS Autoscan up as a separate topic, I will have a look.
  10. #570
    Sep 2011
    Thanks RW1,
    I will try to get a read-out from the dealer and will post it in a new tread.
    Cheers,
    regu
