Page 54 of 139 FirstFirst ... 444525354555664104 ... LastLast
Results 531 to 540 of 1381
Thread: Golf 118 TSI Engine Failures and Service Campaign 24S4
  1. #531
    Sep 2009
    Melbourne, Australia
    Hi all,
    My 118TSI just turned its toes up last night, though it's always felt a bit shuddery at idle. Always run it on BP Ultimate, had the ECU reflash done as soon as it was available and the car isn't thrashed (I have a Boxster for that!).
    I ran a scanner over the ECU once I got the car home:
    5 Faults Found:
    000051 - Turbocharger Bypass Valve Control Circuit
    P0033 - 000 - Malfunction / Open Circuit
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 1048575 km
    Time Indication: 0
    Date: 2111.15.31
    Time: 31:63:63
    Freeze Frame:
    RPM: 231 /min
    Load: 56.4 %
    Speed: 0.0 km/h
    Temperature: 12.0∞C
    Temperature: 12.0∞C
    Absolute Pres.: 1010.0 mbar
    Voltage: 10.160 V
    004949 - Cylinder 1 Ignition Circuit
    P1355 - 000 - Open Circuit - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 23744 km
    Time Indication: 0
    Date: 2029.14.24
    Time: 18:51:23
    Freeze Frame:
    RPM: 1103 /min
    Load: 26.3 %
    Speed: 0.0 km/h
    Temperature: 12.0∞C
    Temperature: 12.0∞C
    Voltage: 14.097 V
    000768 - Random/Multiple Cylinder Misfire Detected
    P0300 - 000 -
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 23744 km
    Time Indication: 0
    Date: 2029.14.24
    Time: 18:53:11
    Freeze Frame:
    RPM: 2105 /min
    Load: 100.0 %
    Speed: 31.0 km/h
    Temperature: 23.0∞C
    Temperature: 14.0∞C
    Voltage: 14.097 V
    000769 - Cylinder 1
    P0301 - 000 - Misfire Detected
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 23744 km
    Time Indication: 0
    Date: 2029.14.24
    Time: 18:53:15
    Freeze Frame:
    RPM: 1903 /min
    Load: 16.1 %
    Speed: 29.0 km/h
    Temperature: 24.0∞C
    Temperature: 12.0∞C
    Voltage: 14.224 V
    004874 - Cylinder Disabling
    P130A - 000 - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 23745 km
    Time Indication: 0
    Date: 2029.14.24
    Time: 18:54:02
    Freeze Frame:
    RPM: 1935 /min
    Load: 40.4 %
    Speed: 29.0 km/h
    Temperature: 33.0∞C
    Temperature: 13.0∞C
    Voltage: 14.224 V
    Coincidentally I was planning on putting the car up for sale as I didn't want to deal with problems once the warranty ran out. I'll hopefully find out what's going to be done tomorrow once I get it towed to the dealership.
  2. #532
    Jan 2010
    UK Cheshire
    There's something a little odd about those faults. A group of 1 and 4 others at a different period. When was the last time you scanned the ECU prior to this posted scan?
    VW SCIROCCO 1.4TSI - DSG (MY2010) UK, East Cheshire.
    Build Complete October Wk43/09, Driving 4th November - Wk44/09. Sorted !
  3. #533
    Feb 2008
    Quote Originally Posted by tazza View Post
    Got a call from VW Dealer . One of the pistons is losing compression . Dealer replacing the Base Engine.
    Is this a good thing. How does it affect the resale value of the car.
    Also would this change my oddometer reading?
    Hate to disappoint but I traded my 118tsi after finding out it needed a new motor. VW said it wouldn't affect resale but they only gave me 18k (bought it for 36k 2 years prior)....
    I am so glad I got rid of that POS as soon as I could. Worst car I ever owned.
  4. #534
    Sep 2009
    Quote Originally Posted by RW1 View Post
    I never had the equipment to scan it, unfortunately. I agree, the turbo bypass circuit date is very odd, but that may just be the software we used having trouble with it. There's a loud clicking noise when the RPMs reach the point where the supercharger would disengage. This wasn't there before the check engine light started flashing so I believe they're all from the same period regardless of what the time stamps say.
  5. #535
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by Squozen View Post
    ..My 118TSI just turned its toes up last night,...
    Hi Squozen
    Curious - What do you mean by toes up?
    You seemingly got it home under its own power. Was it just the CEL light that came on but the car kept running fine. Or did it actually s*1t itself and the engine suffered a catastrophic failure? Toes up is pretty vague. Could mean a lead came loose or you have hole in the side of the block!
    Ignore the dates on the Scans. They are always wrong. But the the kms should be correct. That being the case the first message should be the only one to look at. According to the scan the fault only happened once.
    The others happened 80,000km ago or a lifetime ago. Was that per chance about the time you got the ecu flashed? If so they probably just failed to clear those messages at the time, so you could ignore them.
  6. #536
    Sep 2009
    I've done less than 24k on the car. By 'turning toes up' I mean that the check engine light started flashing and the engine started violently misfiring. I basically rolled it home as I had only driven it for 30 seconds before this happened.
    I should know what is happening early this week but the service tech I spoke to was talking about 'putting a report together for VW Australia' so it sounds to me like he expects this to be an engine replacement.
  7. #537
    Sep 2009
    Good news! The engine has not died. Bad news! The problem was rodents in the wiring harness and I'm out $1700 for a new one!
    FML.
  8. #538
    Sep 2009
    seaforth, nsw
    Any reason for having Rodents in ur engine?
    2011 cw golf gti 3dr man-tint-rear cargo mat-weathershields-bluetooth-mdi-19" oz racing ultra leggera-mcgard lockbolts-boston acoustic pro60se-jl audio xd700/5-jl audio bass tube bb-w060p- titanium exhaust tips-eibach custom pro-kit-OPS-OSIR cf mirror covers and cf front lip-dieselgeek short shifter
  9. #539
    Sep 2009
    I wish I knew! I guess they liked the warmth. I'm looking on the bright side though as they had also built a nest on top of my boxster's engine and that would have been a lot pricier to repair.
  10. #540
    Apr 2010
    The techie who found them must'v have had a nice surprise when he found them.
