Originally Posted by
AdamD
If the issue really is related to fuel quality (and it's all speculation at this point, based solely - I believe - on the lack of issues in overseas markets), then that's precisely why VW is in the process of providing an ECU remap - to allow the engine to better cope with the fuel the car has been advertised as being compatible with, under the conditions under which it must operate.
However, just because a car can operate with a certain grade of fuel doesn't mean it'll operate at peak efficiency with that fuel, especially when it's been designed as the VW petrol engines have, with European fuels in mind. I consider 95 RON fuel the equivalent of a junk food diet. Without the best fuel the car won't operate as powerfully, or as economically, and there may well be longer-term side-effects - which you may not be able to attribute directly to the fuel (and so warranty claims are not cut-and-dried).
As an aside, the "premium" 98 RON fuels in Australia aren't the equivalent of 95 RON with a higher octane rating - they typically have special additives and cleaners added to reduce engine deposits and keep the engine running better over time (and, as Corey has pointed out, have a lower sulphur content as well).
In my opinion, choosing to use 95 RON fuel because "the brochure says 95RON" is counter productive. Sure, it may be cheaper in the short term, but it potentially compromises the performance and long-term efficiency of your car, and your ownership experience. For that reason I never use anything other than 98.
Everyone knows all that. You missed my point.
If VW recommends 95RON, then that is what I should be able to use without any risk of damage. I don't care about the money. I have an XF Jag, the Golf is just for my wife.
118TSI, DSG, Candy White, Sunroof, RCD510, Dynaudio, USB + iPod cable, Reversing Camera, Adaptive Chassis Control, Prem. Bluetooth, Fogs, Tint and Mats.
