Page 15 of 139 FirstFirst ... 513141516172565115 ... LastLast
Results 141 to 150 of 1381
Thread: Golf 118 TSI Engine Failures and Service Campaign 24S4
  1. #141
    Feb 2009
    Sydney, Australia
    From what I can tell, the poor Australian fuel is probably to blame here. It's really starting to impact the European manufacturers heavily. These engines are being designed for 'Euro 5' regulations in relation to fuel consumption and emissions, yet our fuel is far below the quality level which Euro 5 requires. One of the big things it the sulphur level in Australian fuels is several times what it needs to be, but it may be more complex than that.
    In relation to your engine, there are other members who have had the entire engine replaced. If I were in your position, I would push the issue and ask that this happens to your car as well. I'm not mechnical (well not to the extent of understanding this procedure), but I don't undestand how they can "replace a cylinder" in an engine. Pistions, cylinder heads, sure, but not a cylinder itself. I would feel much better if the entire engine were replaced if it were my car.
  2. #142
    Closet Diesel Owners Club President.
    Isn't BP Ultimate very low sulphur or is it just lower than the rest of the aussie junk but not lower than europe?
    *Disclaimer - Don't rely on me, seek your own professional advice. Audi R8 E-tron. 230kw 4500nm! (not a typo).
    Economy at 100kph =5.5L
  3. #143
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by Golf Mark 6 View Post
    Thought I'd share my sad story with you...
    That is indeed rotten luck for you. As I have the same car I am mildly concerned. Out of interest have you been using a particular bread of fuel and was it it alway 98RON or were you using 95RON as well a bit? I am open minded to as to the cause by the way. I have a hunch related to emission controls, not fuel, but will not be able to check until I see how my car compares after any ECU "fix" via VCDS. Anyone know at what part of operating regime this engine is exposed to the greatest heat stress?
  4. #144
    Nov 2009
    Rowville, Vic
    Does anyone suggest a certain brand of fuel?
    ~Nic~
    Deep Black Mark VI Comfortline 118 tsi - manual/sports pack, MDI
  5. #145
    Jun 2009
    Quote Originally Posted by nicandlance View Post
    BP Ultimate > *
    See here: http://www.vwwatercooled.org.au/f77/...mium-9335.html
    To everyone:
    If you are spending over 30k on a car, why would you cheap out a dollar or 2 every fortnight and run your car on poorer quality fuel.
    If it's that much of a pricing issue, just don't have one coffee in that fortnight and you will be ahead.
  6. #146
    Mar 2010
    Omnipresent
    95RON is recommended isn't it?
    Why should we have to pay for 98RON?
    118TSI, DSG, Candy White, Sunroof, RCD510, Dynaudio, USB + iPod cable, Reversing Camera, Adaptive Chassis Control, Prem. Bluetooth, Fogs, Tint and Mats.
  7. #147
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by team_v View Post
    Would like be interested in the results in that thread, if blind testing had been done. Where the users did not know which brand was in their car at any given time. Also would be interesting to see what difference between the commonly available 98 ron fuels are based on scientific testing. In the mean time I am happy to use any 98 RON from a mainstream brand without feeling cheap. I sure cant tell the difference.
  8. #148
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by POLARBEAR666 View Post
    BP Ultimate 98 Unleaded contains less than "50 parts per million of sulphur". This is less than 2/3 the amount of sulphur in regular unleaded fuels (including 95 octane premiums), which are up to 150 ppm.
    Euro 5 compliant fuels, which are (not quite so obviously) required for Euro 5 compliant engines contain up to 10 ppm maximum.
    This means that even BP Ultimate is 5 times higher than the engines are designed for!!!
    But regular 91 and 95 unleadeds are 15 times higher than the engines are designed for!!!
    This is particularly troublesome during "lean burns". If anyone remembers the comments and pictures posted by someone here a while back in relation to the 118TSI engine failures, fuel leanness (is that a word?) was bought up as a likely problem. The sulphur content in Australian fuels is also causing issues with BMW and Mercedes. They both have new motors that they simply cannot bring to Australia because of how bad our fuel is. Despite these engines being far cleaner and far more fuel efficient than the current generation of engines available.
  9. #149
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by BBP View Post
    See my post above...
  10. #150
    Mar 2010
    Omnipresent
    Quote Originally Posted by coreying View Post
    Thanks for the above and I understand your explanation.
    However, if the brochure says 95RON, then that's what I'll be using. If VW have released an engine that can't cope with 95RON then that is a Fair Trading Act issue for them - misleading and deceptive, not fit for purpose etc.
    Let the warranty claims roll on !
