Page 123 of 139 FirstFirst ... 2373113121122123124125133 ... LastLast
Results 1,221 to 1,230 of 1381
Thread: Golf 118 TSI Engine Failures and Service Campaign 24S4
  1. #1221
    Oct 2018
    I've just had this same issue happen with my 2013 Jetta 118TSI CTHD engine at 50,000KM. Issue was rough idling, and CEL flashing.
    VW are doing a goodwill repair on this currently .
    Initially took it to my mechanic who confirmed the car logged a misfire in Cylinder 4. As a result of this he changed spark plugs and had me run injector cleaner through the next tank of fuel - I added fuel cleaner and filled the tank that day. It still felt rough and occasionally the CEL would flash a few times, however driving was OK for the next ~300KM - the CEL came on intermittently and the rough idle did not go away.
    After 300KM the idling got rougher, and the EPC light came on. I took it back to my mechanic who diagnosed low compression (50 psi), and advised I take the car back to Volkswagen as the engine would need to be taken apart by them.
    I called around to a couple of VW Dealerships. The first dealership didn't seem to want to deal with my car. I asked about the cracked piston issue, and was advised that since my car was a 2013 / CTHD engine, it shouldn't be a cracked piston. I was told the current wait time before they would be able to disassemble and look at my engine was 7 weeks, then they we could apply for a goodwill repair..
    The second dealership was much more helpful, and advised they could look at it the next day (and would be able to disassemble the engine later that week if required). I was advised if it is the cracked piston issue that they will apply for a goodwill repair from VW Australia.
    As I didn't want to risk (further) damage to the engine (it was ~20KM drive, and I wasn't sure the car would make it), I had the car towed to this VW Dealership on Wednesday. Initially authorising ~2 hours of labour to diagnose/confirm where the fault was.
    I was given a call later that day (Wednesday) to advise that the technicians suspected it was a cracked piston, however would need to disassemble the engine to confirm, and then could log a good-will request with VW Australia. I approved this labour with the understanding that this would probably be done by Monday.
    On Monday I called to follow up, I was able to speak to someone in the service department, however not the person who worked with my car, who advised that they could see parts had been ordered parts for my vehicle (a new engine) - I queried this as I had only approved the labour for engine disassembly at that point.
    The tech advised he'll get back to me, and after ~20 minutes called back advising this is a good will repair, with VW Australia covering parts & labour (including the labour to disassemble the engine). I was advised this work should be completed by Friday.
    Even though the service department is not open on Saturday I was advised I can still pickup over the weekend (they can provide codes to a lockup garage on site), I need to confirm the details for this however. I guess any paperwork for the vehicle would be done at the associated dealership (which is open Saturday).
    Overall I'm pretty happy with Volkswagen & the dealership's handling of this.
    I should get the car back either Saturday or Monday. I'll let you guys know if I have any issues with the car next week, or if there are any hiccups with getting the new engine.
  2. #1222
    Jul 2018
    Quote Originally Posted by Yapa View Post
    Update:
    My suspicions were correct and it was a cracked cylinder causing the engine light and rough idle.
    The dealer checked the car and ruled out any other possible cause, saying it could be compression failure on the cylinders but would not know until they took the engine apart.
    To look further it would be $1500 to $2000 to take it apart. At that point I told them to wait and contacted VW Customer Experience.
    They were very good, giving me a hire car immediately and liaising with the dealer about the repair. It's been a few weeks but today I got the confirmation of a goodwill repair.
    Overall very happy with VW customer care and how its been handled by them, gives me confidence in the brand and would recommend and buy another VW.
    I hope any others in the future experience the same support, good luck.
    So just 2 months and approx 5000 KM's after getting my car back with rebuilt engine the gearbox blew.... just heard a loud poping sound and lost all drive. The P R N D gear letters are flashing on the dash and the car seems to be in neutral all the time.
    Had to get it towed home.... very disheartening ...
  3. #1223
    Bugger!!! Golf 118 TSI Engine Failures and Service Campaign 24S4
    I wonder whether VW are going to be as good with this on and fix it under goodwill.
    Erskineville, NSW
    crap engine
    crap gearbox
    worst VW driveline ever.
  5. #1225
    Far out - sorry to hear. Fix it and get rid of it. Must be hard to imaging buying another VW product again.....but this engine and gearbox used in the 118TSI really are cursed and are literally a ticking time bomb. Thankfully, other VW products are much more reliable.
  6. #1226
    Jul 2018
    It's back at the VW dealer who repaired the engine.
    Waiting on diagnosis but have since found that the mechatronics unit in these 7 Speed gearboxes was recalled... I believe it should have been done by VW as it's always been serviced by VW but who knows?
    If it is the gearbox and expensive hopefully VW comes to help again, never had such a troublesome car before...
  7. #1227
    Yes i believe there have been 2x separate recalls on the 7 speed DSG used in the 118TSI - one for the oil to be replaced, and another which was either clutch packs or mechatronics. Someone else who has 1st hand experience should be able to clarify this.
  8. #1228
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by BlueSteel View Post
    Is this the first CTHD that has been seen on VWWC?
    As you said, the newer revision was supposed to be much better and I don't know that I've heard of another one going like this?
  9. #1229
    Jul 2018
    Just got the call from dealer and was quoted $33xx for the mechatronics unit...
    He said they would speak with VW customer care.
  10. #1230
    Jul 2018
    Good news, VW have agreed to cover the repair costs in full! Very happy to as the least!
