Page 114 of 139 FirstFirst ... 1464104112113114115116124 ... LastLast
Results 1,131 to 1,140 of 1381
Thread: Golf 118 TSI Engine Failures and Service Campaign 24S4
  1. #1131
    Oct 2017
    Quote Originally Posted by VW Convert View Post
    As sixboltmains has stated, some owners have been reimbursed these costs, it seems to be on an individual case basis but as yours is such a low mileage example, I would be pushing for it from the get go.
    One important thing to remember, you refer to it as goodwill............you need to be clear on this, it is not goodwill it is rectification in accordance with your statutory rights as set out under Australian Consumer Law as it is a reasonable expectation that an engine will last longer than 67,000 KM.
    When you discuss this with your dealer, make sure they understand that you know that this is a known issue, that you are aware there have been countless examples where VW has rectified this issue well outside of the usual warranty period and that you are not asking for a favour, you are asking them to rectify their flawed product as they are required to do.
    George
    Thankyou for this.
    I spoke with the Dealer service centre today and it was made clear that no claim would be progressed unless we cover the $1200 diagnostic stage ourselves. He was really polite and sympathetic but no admissions were made that this is a known problem.
    It was also made clear that the $1200 is just to take it apart, and for them to put it back together would be a couple of thousand more - so at this stage I have no option but to pay the full diagnosis amount and keep my fingers crossed for a good outcome from head office.
  2. #1132
    Jun 2016
    Bulgaria
    It`s so disgusting for VW to deny the massive problems with 1.4 engines. It`s a known problem everywhere.
    My opinion for VW drops with every single day. I like they design of the car so much, but their reliability lately is a nightmare ....
    When i was asking VW dealer for the problem i have with mine - huge oil consumption, and that this is a known issue and how they blow engines, he also said they know nothing about it and don`t believe internet story.
    After some advance talk, they admit they have a "small" problem with the piston rings, and the consumption it`s probably because of that. I said okay, great, lets just change the piston rings, and he was like - uh... you have to change the piston to, he also said i need to change the piston rod to, cause i can`t run the new piston with the old rod ....
    Yeah minor piston ring problem ....
    Of course not good will or anything has been offer, but to pay for the full repair or to drive the car with 1l oil consumption per 1000km.
    And as you already known i was thinking of getting forged pistons, but after the next problem with the DSG i sell the car.
    I hope all goes well for you. This is a VW production mistake and they should have made a service recall and change all the pistons for free.
  3. #1133
    Oct 2017
    Quick update. We have a cracked piston in Cylinder 4. The dealer has just written to VW Australia. I will report back.
    In the meantime, I did a bit of research through these threads to pin down the number of successful cases where VW have coverd the cost of all or part cost of repairs. I went back to January this year and tracked each instance. I thought I would share here as a resource for others.
    The short story is that between January and October 2017 - as far as I can see - there were 15 instances where VWA covered the entire cost of the repair and two cases where they covered only part of the cost - in both cases this was due to patchy servicing, high KMs. One case where no costs covered.
    Please correct me if I've missed anything. Here is the table I made. I thought it might be worth keeping a running tally. I'll update when I know the outcome of my claim:
    FULL COST COVERED
    Church
    Redhot
    Lachlan MC
    Anapo
    Bensi
    Svandas (including a loan car)
    Billables
    Saveferris
    Ellwith
    Axyl
    Nick123
    JoshDC
    Zackzorr
    theHawk
    PART COSTS
    1/2 Costs - smokiebear
    75% cost Sosotired
    NOT COVERED
    sixbolt
  4. #1134
    Dec 2006
    Kilsyth, VIC
    I think there has been a real positive change in their customer service over the last few years and it's pretty hard to say VW aren't supporting their brand based on that recent sample.
  5. #1135
    I had my timing chain fixed in march but it still made the rattling sound so sent it back to fix and also the gearbox was playing up due to clutch packs. They kept the car for four bloody months but ended up fixing everything under goodwill. Now after it came back its Still making the timing chain rattle after it was all replaced!!!!
  6. #1136
    Oct 2015
    UK
    Quote Originally Posted by ExplosivePeacock View Post
    9 times out of 10 the 'rattle' is misdiagnosed as a loose timing chain or failing chain tensioner.
    On this engine it is almost never the chain or tensioner that makes this noise - the noise on startup is the camshaft adjuster sticking, which admittedly sounds like a rattling timing chain to in the untrained ear.
    The problem effects engines from 2009 to mid 2010. After that the camshaft adjuster was revised to stop this problem.
    Some people who have had the timing chain replaced, also had the adjuster replaced at the same time and this inadvertently resolved the problem.
    Only a poor dealership would not replace the adjuster at the same time.
    Since 2015 there are 2 official VW universal timing chain kits for all 1.2, 1.4 and 1.6 FSI/TSI engines, which come with a new camshaft adjuster - this kit is cheaper than buying the chain, tensioner and parts separately. This kit should be used for any timing chain job, as its cheaper and you get all new sprockets, guides, tensioner, chain and camshaft adjuster (latest version).
    Check out a post I made here (froudeg) to diagnose what sound is what: Scirocco Central • View topic - Sounds like a tractor on start up?
  7. #1137
    Quote Originally Posted by blower View Post
    Hmmm the camshaft adjuster could be the problem, I am pretty sure it was not replaced with the timing chain and tensioner
  8. #1138
    Oct 2017
    Quote Originally Posted by Kaliani View Post
    FULL COST COVERED
    Church
    Redhot
    Lachlan MC
    Anapo
    Bensi
    Billables
    Saveferris
    Ellwith
    Axyl
    Nick123
    JoshDC
    Zackzorr
    theHawk
    PART COSTS
    75% cost Sosotired
    NOT COVERED
    sixbolt
    Just a quick note to report that we got a call back to say VW Australia will cover 100% of the cost of repairs (2 cracked pistons).
    Really pleased with the VW customer service. The dealer handled it all and we didn't have to argue for it. Offered within a couple of days. We now feel comfortable enough to go and order our brand new VW Golf alltrack this weekend, and trade in the old Jetta .
  9. #1139
    Dec 2006
    Kilsyth, VIC
    It sucks that it happened in the first place, but you can't ask for a better outcome on this side of things.
  10. #1140
    Jan 2010
    Just picked up my 118TSI from being repaired due to piston failure, 59k on clock
    100% of costs covered as a goodwill gesture
    thanks VW Australia
    08 MkV GTI Pirelli --- 65 Split Screen Container Van
