... except for when you are stopped when the Word Setup should be at the top.
So when it disappears are you saying it replaced by blank space or replaced Audio for example? If you were in MFD and Audio suddenly displays overwriting time/gear one would suspect a problem with the Right select button.
Cars with NAV and other fancy gear have extra info displayed up there, so they will have other items in the sequence. Wonder if your instrument cluster has been coded to have NAV fitted and it is "looking" for it periodically.
