Reading all these posts made me realise I should restate my suggestion to Newtogolf another way.... if you experiment with different change points, you will soon figure out the revs that the engine falls to AFTER the gear change.
Anyone who owns a 118TSI would agree that at least 1,500 rpm AFTER a gear change will give you just enough performance for day to day suburban driving (in the gear you have shifted TO). 1500rpm happens to be around where max torque is occurring to give you the additional comfort you're not "stressing the engine"... so I say just shift at whatever point happens to give you at least 1,500rpm. That will give you the blend of economy & performance you are looking for.
I've noticed that shifting around 1,900rpm happens to give you this result - but it depends on each gear - but this is a general rule. Of course the rpm's you give will depend on situations such as whether your on a hill, whether you have momentum etc etc
For instance, if you're going downhill, 1,200 rpm is enough to get you going. If you're going uphill, you may want more than 1,500rpm to 'start' with (but I'm amazed that 1,500rpm is enough after a bit of experimentation).
Those who haven't driven an FSI based vehicle recently, you will be amazed at how responsive the engines are these days at low revs. My mk5 2.0 FSI was a revelation. A test drive will put a shock
and grin on your face like countless mk5/mk6 owners with an FSI based engine (I'm including the turbo & TSI engines in this statement as they all use direct injection)
Skoda Octavia Mk3
(sold) Golf Mark 6 Comfortline 118
(sold) Golf Mark5 Comfortline Manual 2.0 FSI
