In engine bay or inside the car or all?
The one under the bonnet, does it look like this?
Has anyone got a diagram of the fuse layout for a GTI? For some reason its not in the manual which is highly annoying!
Simon
Forever blowing bubbles.
If it's the interior fuse box, the story I was given is that they only fit the fuses for what's in the car as it leaves the line, so a diagram would lead to confusion (probably a copout for being too lazy to indicate fixed and optional circuits.)
Was after the one for inside the car, want to hook up the boost gauge lighting to the headlights fuse (I assume it would have one fuse for the sidelights and low beam?), if there is one?
For that, you could take the power from the headlight switch.
No it doesn't. Have had mine running that way for about four years. I actually used the dimmable power so the gauge matched the rest of the instrument cluster.
Graphite Blue TDI| DSG | Leather | Bi-Xenons | Custom LED inner tails | Black Forest TAI | OSIR Pod & New South Boost Gauge | Bluefin | Projector Fogs | RNS510 | Skoda Bluetooth | Eibach Pro kit Springs| Full LED interior|US GLI paddle shift MFSW|Carbon Vinyl wrapped trims|Colour Coded Votex Body Kit|
Awesome thanks everyone!
Sorry for the resurrection but does anyone know which wires on the back of the headlight switch I should splice from for the boost gauge?
