Results 1 to 10 of 10
Thread: Fuse box diagram
    Jul 2007
    Canberra
    Fuse box diagram
    Has anyone got a diagram of the fuse layout for a GTI? For some reason its not in the manual which is highly annoying!
    Simon
    Forever blowing bubbles.
    Adelaide hills, SA
    In engine bay or inside the car or all?
    The one under the bonnet, does it look like this?
    Dec 2009
    Kew, VIC
    If it's the interior fuse box, the story I was given is that they only fit the fuses for what's in the car as it leaves the line, so a diagram would lead to confusion (probably a copout for being too lazy to indicate fixed and optional circuits.)
    Jul 2007
    Canberra
    Was after the one for inside the car, want to hook up the boost gauge lighting to the headlights fuse (I assume it would have one fuse for the sidelights and low beam?), if there is one?
    Adelaide hills, SA
    For that, you could take the power from the headlight switch.
    Jul 2007
    Canberra
    Cheers, thanks all
    ---------- Post added at 06:57 PM ---------- Previous post was at 06:55 PM ----------
    Taking a splice off that wouldn't cause any faults/error codes?
    Apr 2008
    No it doesn't. Have had mine running that way for about four years. I actually used the dimmable power so the gauge matched the rest of the instrument cluster.
    Graphite Blue TDI| DSG | Leather | Bi-Xenons | Custom LED inner tails | Black Forest TAI | OSIR Pod & New South Boost Gauge | Bluefin | Projector Fogs | RNS510 | Skoda Bluetooth | Eibach Pro kit Springs| Full LED interior|US GLI paddle shift MFSW|Carbon Vinyl wrapped trims|Colour Coded Votex Body Kit|
    Adelaide hills, SA
    Quote Originally Posted by Pullstarter View Post
    Cheers, thanks all
    I checked the wiring diagram and it's safe to tap in.
    Jul 2007
    Canberra
    Awesome thanks everyone!
    Jul 2007
    Canberra
    Sorry for the resurrection but does anyone know which wires on the back of the headlight switch I should splice from for the boost gauge?
