Results 1 to 9 of 9
Thread: Fuel gushing out
    Sep 2011
    Fuel gushing out
    Hi.
    Notices fuel gushing out of the back of the car when it started. After a quick investigation it is coming of a black fuel line cable that plugs into a metal cylinder.. Fuel pump? Anyways I tried to plug it back in but when you start the car it busts right back out. Any tips about trying to get this back in?
    Sep 2011
    after a quick google.. im thinking that this is not the fuel pump but the fuel filter?
    Mar 2013
    Brisbane QLD
    yes its the fuel filter and it should just clip back on when you push to onto the filter... to release it you push a tab down on the connection but to refit it you just push until it clicks in... when you push it back on try and pull it off again.. it should not move....VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Sep 2011
    i pushed it back in as hard as i could and it still comes out. Do you think its ruined?
    Sep 2011
    looks like the clip is missing?
    Mar 2013
    Brisbane QLD
    if you look at the blue return pipe in the picture it has a black connector but a blue clip... the black pipe should be excactly the same (but not blue) see if you can see the clip on the black pipe.. can you press the clip ?? VDUB....
    Sep 2011
    Quote Originally Posted by vdubmotorworx View Post
    Yeah I checked it out. There's a slot there where I assume the black clip
    Would be and I felt around and couldn't see or feel it.
    Dec 2008
    Sydney/Canberra
    Had the fuel filter replaced recently? It looks new.
    Worst case, you can replace that whole section of fuel line, as it just runs from the top of the fuel pump, above the tank.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Apr 2006
    VW Race HQ - Sydney
    Use zip ties to hold it in . Ive seen the clips absolutely butchered and its a good short term fix . New fuel line looks like its the go though , those clips arent really repairable .
    Bug_racer supports the rebellion of the euro revolution
