Hi all,
I had an 8 sensor PDC OPS retrofitted on Golf mk6 2.0TDI 140hp several weeks ago in a local garage.
Unfortunatelly, the module was faulty (not OEM) and the guy who mounted the OPS advised me to buy a new one.
I purchased one from eBay (OEM) with part number 5K0919475E.
Now, I cannot visit the local garage because they messed up other parts of the car (this is another story) and after fitting the new module I get a long beep and a flashing rear sensors button. I purchased a VCDS to check what is going on and got this code error:
I gues the error code is pretty self explanatory - the new module needs to be coded.Code:Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb Part No SW: 5K0 919 475 E HW: 5K0 919 475 E Component: PARKHILFE 8K H01 0012 Revision: -------- Serial number: 12532131601725 Coding: 000000 Shop #: WSC 00000 000 00000 VCID: 387CBFD4B3621447CF-806C 1 Fault Found: 01042 - Control Module; Not Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 220 Mileage: 188557 km Time Indication: 0 Date: 2016.11.28 Time: 21:30:59 Freeze Frame: Temperature: 30.0°C
I will very much appreciate if anyone can help with the coding part or at least share some resources that would
help me code the module.
