Bottom of the B-Pillar? Can't remember which side.
They probably just want to know if you have 50mm or 55mm strut diameter.
If you have a GTI it's 55mm
Hi all I'm looking at a set of Coilovers the company has asked for the front load axle load does anyone know where this plate is? I can't find it.
thanks guys
Thanks Brad yeah I have a mk6 GTI. Will check it out
Alrighty found the plate but is blank. Printing in it vin number on it and the kg but no numbers. My GTI is Apr 2011 build if that helps
Have you looked in the owners manual?
I found on the AwesomeGTI website there is 4 options in AP Coilovers - 2 options in 50mm (1060kg OR 1061-1170kg) and 2 options in 55mm (1060kg OR 1061-1170kg). Anyone have an idea on which one??
MK6 GTI is 1060F / 880R
Volkswagen Golf MK6 suspension from KW
The >1061 is for the TDI models & the R
Thanks Brad!
Just need some confirmation before I order a set of Coilovers, is brad^^ right with the axle weight??
thanks all
The 50mm strut is for 77TSI - 118TSI. The GTI and R (and i believe TDI's but not 100%) use the larger 55mm diameter strut.
TDI are heavier in the front (diesel engines are heavy) and both the R32 and R models are also heavier in the front due to engine/gbox config for the AWD systems.
