It looks like a drive shaft bolt?? Could be wrong!! But normally some do not have the washers
It worth having a look. Turn your steering wheel to lock and check each side of the shafts which connect to the DSG.
I found this bolt and washer under my 2009 Golf mk6 TSI118 DSG
The bolt is around 30mm long and the washer is around 20mm wide.
Could anyone please confirm its from the Golf and if so, let me know where it belongs?
Thanks,
Steve
Can't say I've seen any bolts like that while poking around my engine bay. Also wouldn't any bolts that come off come to rest on your plastic engine tray instead of hitting the ground. I would think it more likely the bolt got kicked under there or something... but I'm not a mechanical expert.![]()
Its not familiar but have to say being the 10mm spline, they are used in many parts of the dub, would need to be up on a hoist to confirm
Jmac
Alba European
looks like the bolt that hold the exhaust cat mount to the engine block should have 2 each side of the cat.
could be a swaybar endlink bolt....
did you upgrade your swaybar recently ?
