Results 1 to 10 of 11
Thread: Found a bolt and nut under my Golf Mk6
    Sep 2012
    I found this bolt and washer under my 2009 Golf mk6 TSI118 DSG
    The bolt is around 30mm long and the washer is around 20mm wide.
    Could anyone please confirm its from the Golf and if so, let me know where it belongs?
    Thanks,
    Steve
    Jul 2011
    It looks like a drive shaft bolt?? Could be wrong!! But normally some do not have the washers
    It worth having a look. Turn your steering wheel to lock and check each side of the shafts which connect to the DSG.
    Apr 2010
    Can't say I've seen any bolts like that while poking around my engine bay. Also wouldn't any bolts that come off come to rest on your plastic engine tray instead of hitting the ground. I would think it more likely the bolt got kicked under there or something... but I'm not a mechanical expert.
    Aug 2007
    Its not familiar but have to say being the 10mm spline, they are used in many parts of the dub, would need to be up on a hoist to confirm
    Jmac
    Alba European
    Sep 2012
    Quote Originally Posted by grtuned View Post
    Thanks for the helpful suggestion. I check that I still have all the drive shaft bolts. They seem to be similar to my mystery bolt and come without any washers.
    brisbane
    looks like the bolt that hold the exhaust cat mount to the engine block should have 2 each side of the cat.
    Apr 2006
    VW Race HQ - Sydney
    Quote Originally Posted by bushnut View Post
    Id put it more as this , its definately not a CV bolt , never seen one with a washer on it .
    Bug_racer supports the rebellion of the euro revolution
    Mar 2012
    Sydney NSW
    could be a swaybar endlink bolt....
    did you upgrade your swaybar recently ?
    Apr 2006
    VW Race HQ - Sydney
    Quote Originally Posted by bennjamin View Post
    They use a 18mm nut and the bushes use a 13mm bolt
    Last edited by Bug_racer; 09-09-2012 at 08:27 PM. Reason: thought it was a polo <crazy face>
    Sep 2012
    Thanks for the helpful suggestion but there have been no modifications to the Golf. Its all factory standard.
