Have you googled the fault codes as there is plenty of info out there. What are you using to give you the codes. If an OBD11 press the blue G at the right side of each line.
Hey everyone, I have a Golf mk6 2013 1.4l
It’s having issues with the transmission where it goes into limp mode within the first few kms (the car loses all power and needs to be restarted) and then I can restart the car and it drives fine, though sometimes it does it multiple times.
It has a few error codes which I’m trying to decifer what the issue may be. I was told it’s potentially the mechatronics, but would like some advice here before replacing it. Do these codes point towards the mechatronics needing replacement or could it also be something else. I don’t want to replace it unnecessarily.
The error codes are as follows
Transmission:
002113 - transmission fluid pressure sensor /switch 1 - P0481
006293 - functional restriction due to pressure drop - P1895
006300 - functional restriction due to pressure build up - P189c
006079 - hydraulic pump P17bf
Any advice or hints would be great.
Google the codes, could be the accumulator close to failing. That's very common
