Originally Posted by
Maverick
And engines and oils are different now. Modern oils may be improved but they have a lot more to do..
And they can handle it much better. The revolution goes all the way from whipper snippers to power generation equipment.
Maverick
Chevron Oil has a technical doc that shows 70 percent of the parasitic drag is from the shearing of oil molecules between bearing surfaces and bearing journals..
Yes, it's always been the case. that's one of the reasons oils are now lighter
Maverick
Change the oil more often and it reduces this..
Evidence? The study quoted by Diesel vert seems to reach a different conclusion
Maverick
Oils are lighter now and are expected to work harder which reduces their life as does the temperature of the engine which are hotter than ever before (for efficiency reasons). More power is being extracted as well, there are closer tolerances and engines work harder.
less blowby, less fuel in the oil, less crap in the fuel, better filters. All these things make the oils job easier. Would you run an engine hard when the oil's cold?
Maverick
That's good but how does that apply to Australia which has different conditions?.
Peugeot Europe 30000 kms, Aus 20000 kms, dealer 10000 kms.
Maverick
The oil is recycled, fuel consumption drops with fresh oil and it protects the engine. Changing the oil often is really the best way to maintain an engine in top condition.
So, you have oil that has had its long chain molecules chopped up, it's no good according to this philosophy. You strain it, add some more additives and put it back in an engine. How does this make more sense than extending the oil change intervals in the first place?
2009 118 TSI
1980 Bedford van
2015 Hyundai i30 SR
