The steering seems fine, it was just the noise that concerned me.. but apparently it has a major fault?
They said they will need it for 3 days to do it all, and it will need a full front end alignment.
Then to top things off the ticking noise from my dash it apparently a faulty "ecu relay" which is $110.
Really seems like vw is trying to bleed me dry atm.
Golf R 5 Door DSG, Rising Blue, 19" Wheels (Silver), Leather, MDI, RVC, Bluetooth, RNS510, APR Stage 2, APR Divorced DP, APR HPFP, VW Racing CAI, S2T Paddle Shifters, Sprint Booster
with the servicing 15000 1yr... is there a "check up" service at all? say 1500/3000ks? as i find it strange that it doesnt.
also how do i change from mobile view to normal view for the site......
Some dealers offer a free check / top-up of the levels. They don't put it on a hoist or anything & you should be capable of checking the levels yourself.
I didn't bother taking them up on the offer as the car was running like a dream & faffing about going to the dealer for no reason wouldn't have added any value to the ownership experience.
I would recommend that you voice your concerns direct to VW customer service. Apparently getting a Goodwill Fix is a bit of stuffing about, so the dealers don't try very hard. Something dot-pointed in writing usually works well. Keep in mind that consumer protection laws now provide for a "fitness for purpose". eg: A reasonable expectation that an item will perform correctly for a certain period of time. I wouldn't think that a 39,000km/3 years is the design life of a DSG mechatronic or a Power steering rack but is probably OK for a ECU relay.
True, the poster in question has an R32, so any mods won't increase power a huge amount but I guess a tune or an intake could be used as fair reasoning not to cover a gearbox. I guess if he's lowered it or done something with the suspension then you are out of luck with the steering rack too. In both cases, 39,000km is still quite new. I would hope that a DSG would be good for at least 100,000km & a steering rack good for at least 150,000km of trouble free motoring - even on a mildly modified car.
Yes, under normal driving conditions, but it also depends where you drive (the roads condition), how do you drive (for example hitting the curbs too often?) and so on. So, yeh, there are a lot of reasons and opportunities for manufacturers to refuse to cover the car that is out of warranty and one could have a hard job to prove otherwise.
But in general, I agree that some components fail way too soon after the warranty. It is a good idea to keep the record of all repairs that were done during the warranty period (don't count on the dealer that he would give it to you if you need it) so they could be used to point out that the component in question was already repaired under the warranty.
