That's actually how I first noticed it. I drove out of the dealer in sports mode and on that mode for about 5 minutes. I was thinking to myself how heavy the steering was compared to my Polo. But then I changed it to Comfort, and went to turn into a side street, and all of a sudden I almost turned the wheel around 3 times it was so light! hehe
website: www.my-gti.com
On my non-ACC car, I've noticed that the steering weighting is quite speed sensitive. While there may be minor adjustments to the weighting at low speeds, it seems to make a big transition around the 80km/h mark - I've noticed it several times while having a go on faster flowing bends, and also whilst changing lanes at varying (higher) speeds.
It'd be interesting to know how much variation there is in the system on an ACC equipped car in various modes, versus a non-ACC car.
I assumed that the steering on non-ACC cars would be too light at higher speeds, however maybe having a lower car helps this?
If my understanding is correct when Adaptive Chassis Control switches to Sport it sends a command via the gateway control unit (in the dash) to the electromagnetic power steering system system to alter it's operation, the same applies when it switches out of Sport mode. The gateway control unit interfaces the control unit behind the drivers side rear wheel to the CAN bus system.
I believe it's the same as the Mark V where it adjusts depending on speed. The steering assistance is controlled by a map loaded in the control unit at the factory, this can be altered but not via VCDS IIRC. The map provides five different settings for 0km/h, 15km/h, 50km/h, 100km/h and 250km/h.
It works with turning the steering wheel which twists a torsion bar, a sender transmits this info along with the steering wheel angle sensor, speed (vehicle and engine) details to the control unit which activates the electric motor to provide assistance based on the map above.
Nice work Guy. Good luck with the Castrol Edge Hot Tuner Challenge with this awesome piece of work.
Have you got some pics of the exhaust? How does the exhaust tone compare to stock?
