Page 13 of 28 FirstFirst ... 3111213141523 ... LastLast
Results 121 to 130 of 280
Thread: First Golf R 420 hp (315kw) build in the world - Australian exclusive!
  1. #121
    Thanks all - appreciate it.
    I am no expert, but with APR chip having a higher air/fuel ratio, wouldnt that create more exhaust? hence producing a different note?
    I could be wrong..
    Delivered: MY11 Candy White Golf R l 3dr l DSG l Black 19s l Sunroof
  2. #122
    Jul 2010
    Melbourne, VIC
    Quote Originally Posted by MattD View Post
    Hi all
    I am new to this forum and I have a white DSG Golf R on order (due Nov - like everyone else)
    Question, when the APR Stage 1 is fitted, does it give the exhaust note more punch? (as well as the obvious benefits..)
    Thanks in advance
    I think it would change the induction sound a little bit due to the increased boost but as the others have said, it wouldn't have an effect on the exhaust note.
    Golf R
    Candy White / 5 Door / DSG / Adaptive Chassis Control / Black 19" Talldega's / Sunroof / Recaro's / RNS510 + Dynaudio / MDI
  3. #123
    Jul 2010
    St Ives, NSW
    This is the second time I've seen an R dyno'd on just the front wheels. I know the Haldex controller can put all drive to the front wheels depending on conditions but do you have to do something to the system to ensure you don't damage it?
    Golf R 5 door, DSG, EVOMS CAI, TXS DP, Recode Tune.
  4. #124
    May 2010
    Melbourne, Victoria
    The stock FSI Carbonio uses the stock engine cover, so no problem there. We are using a modified TSI intake on ours.
    Guy, why did you opt for the modified TSI intake over the stock FSI intake? I am looking at buying a Carbonio intake very soon while I wait for delivery of my R ready for installation upon arrival.
    intake_carbonio_20tsi.html
    carbonio_cai_golfgti20t.html
    The TSI intake looks to use a cone filter while the FSI intake looks to use a panel filter. Are the expected gains better with the modified TSI?
    Is there a stage 2 intake pipe for the FSI intake or is this the same piece of hardware for the TSI usable for the R?
    Cheers.
  5. #125
    Induction noise is probably more noticeable on the R.
    Haldex, disconnecting for dyno purposes is fine, not recommended for long trips as it can overheat the clutches (but this takes a long time). Haldex can not remove drive from the front wheels, only the rear!
    On the intake, we modify the TSI Carbonio for the stage 3 kit. we can arrange this at your local APR dealer depending on your needs.
  6. #126
    May 2010
    Melbourne, Victoria
    Initially I will only be looking at stage 1 tune and the intake.
    After enjoying that for a while I would be looking at upgrading the exhaust. I will then have to decide if I do the downpipe at the same time and move onto stage 2.
    So is the TSI intake much better in design over the FSI intake for a stage 3 tune, in that they look to be different sizes and use different filters (panel vs cone)? If I am going to be sticking with a stage 1 tune (potential to upgrade to stage 2), would there be much difference between the two intakes?
  7. #127
    Nov 2009
    Cook, ACT
    Hi all
    Thanks in advance
    I believe there is a butterfly(?) valve in the exhaust that opens during high flow conditions which adds to the sound. This can be disconnected and set ópen for the sound in low flow conditions. No cost way to add audio character. I think I saw a link in VWVortex to R Forum...
    I'd chase face to face experts befoe disconnecting...
  8. #128
    Jul 2010
    wouldnt be surprised if the golf R cleans up a few hotted EVO's and Subey's in the shoot out. i reckon there are gonna be some huge surprised look on the faces. makes my s3 feel tiny
    MY10 AUDI Q5 & MY10 S38P Forge CAI -- H&R F&R Sways -- Revo Stg 2+ -- Bilsteins PSS10 Coilovers -- AP Racing 6 Piston 365mm Big Brake Kit -- Pagid RS29 Race Pads -- Miltek TBE -- APR HPFP -- Recaro Sporster CS -- Enkei PF01
  9. #129
    Bit of in car from the Golf R at the Tuner Challenge.
    You can see it was not near as much work as the GTI considering lack of grip!
  10. #130
    Aug 2009
    Melbourne - West
    Awesome! Been waiting for this :d
    Bloody greasy track... nearly went off at speed a couple of times. Engine seems nice and responsive, good stuff Guy.
    APR S2/Whiteline/H&R/Enkei/Carbonio/13.68@101/Winton-1:44.52
