Gan, thanks for the info. Hopefully others find it useful. As mentioned, I ended up having an engineering workshop fabricate me one.
Hi All,
The part numbers for the OEM bracket are:
VW-1k0882607A - Bracket
VW-N90897308 - Bolt
VW-1k0881286A - Bracket
VW-N90812302 - Pop rivet
I have this kit under my MkVI GTI passenger seat and it works well without affecting the operation of the seat. I didn't use the plastic cradle or the strap though as these are designed for shorter, stubbier euro fire extinguishers.
On mine, the Quell supplied straps and bracket were bolted onto the VW bracket that got riveted under the seat.
PS: a 25G 'load' on these sorts of fire extinguishers can be handled by a single M3 bolt (the VW design has a safety factor of 3 or 4 in my estimates over the minimum CAMS requirement). And dry powder is CAMS approved. You aren't meant to set it off in the car, you remove it to put out fires that occur in places like the engine bay, oil lines, etc.
Still waiting on it to get done hehe, will have to give them a call and do a test fit. Once its sorted, getting more made up will be easy so I'll discuss with you later in the week mate.
alrighty.....
thanks Dave
I'm needing one of these so headed down to VW to get some prices which I thought I would share. Most were not too bad for factory parts...
1K0 881 286 A - Retaining Bracket - $78.10
N 908 123 02 - Pop Rivet - $1.15 x 3
1K0 882 607 A - Holder for Fore Extinguisher - $125.70
N 908 973 08 - Socket Head Bolt with Inner Multipoint Head - $4.60 x 2
...although I had to ask twice about this one
3D0 860 277 - Fire Extinguisher - $550.80
Conveniently this means you can order all the parts for under $100 then buy an anti fire bottle which is pretty cheap
Sadly the bracket is not currently available and has no ETA. Even the Singapore warehouse doesn't have any so I'll have to start hunting around the globe.
Long story short I'm looking at entering the Supersprint on May 26 so need to get *something* before then if anyone knows where I could acquire one of these or a reasonable alternative.
Sadly it seems that the Retaining Bracket (1K0 881 286 A) is not available in Australia... or the UK... still waiting to here from the USA and Germany. It looks like I might have to find someone who can fabricate an equivalent for me. Have to wonder why this part just seems to have disappeared from stock worldwide
Mine is mounted here using a bracket I had for my Subie (bought it from the local WRX club forum)
However, the bracket was made to be attached to the drivers seat base but won't fit the R so if you find a suitable bracket let me know. I may yet try to adapt mine but as I don't track, no need for now
8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
