Results 11 to 20 of 28
Thread: Fire Extinguisher? MK6
    May 2010
    WA
    Not if he's stuck in his seat/racing harness
    [MK6 GTI MY11 CW 3-door DSG Sunroof Detroits Dark Tint R LEDs APR Stage 1 (regrettably a few years late)]
    And he's just been rear ended
    Jul 2010
    Perth, WA
    he wont be stuck - the car is burning so the seatbelt will probably be burning as well - just tear it off, she'll be right
    Golf GTI MY11 Mk6 Reflex Silver 18inch MDI RSC BT Dark Tint G|Techniq - Buya!
    Oct 2009
    A captain should always go down with his ship...
    or GTI
    May 2010
    WA
    A funny bunch aren't we all
    Tsk tsk...we shouldn't mock the safety of racing drivers...
    Oct 2010
    Quote Originally Posted by Maverick View Post
    VW have a mount that rivets to the underside of the passenger seat. You screw/rivet the fire extinguisher to this mount and it sits under the seat but easy to get at. You can't use this if you have the seat drawers.
    Where would one start looking to get this? I'll call the service centre tomorrow, but I have my doubts
    Jan 2008
    Quote Originally Posted by Dimbles View Post
    Here's the part, I don't have the part number handy but could look it up if the dealer can't find it.
    Oct 2010
    Thanks Maverick,
    I've found a place that will install a bracket and fire extinguisher for $170 Contact European Autotech | European Autotech Sydney. They haven't yet made one for the mk6, but all that is involved is confirming measurements, and making a custom aluminium bracket and then attaching it to the existing seat bolts. I'm going to get this and the APR software from them in the coming weeks, so i'll keep everyone posted!
    Nov 2009
    Does anyone know the part number of this item and if it will fit in under the seat of an R? Can't put it under the drivers seat because I have the bluetooth thing there.
    st l, qld
    Quote Originally Posted by Banzai View Post
    The mount should be fire proof as well as securely anchored. According to the CAMS manual the mount needs to withstand a deceleration force of 25g. Good zip ties can take the load, velcro can't. Neither is fireproof.
    i'd say that if someone were going to mount a +5kg metal object directly behind your lower limbs, that 25g rating might be an excellent idea. exiting the vehicle after a wreck can be hard enough without a shattered leg. as far as accessibility goes, make sure the exinguisher is not a powder extuinguisher if you plan on using it to fight a fire while you are still in the car. you could do it, but the only positive would be that the powder from the extinguisher would probably kill you before the fire did. even if it didn't, you'd be in bad shape for having breathed it.
    Last edited by brisgtimkv; 09-01-2011 at 11:04 AM. Reason: changed subject, i wasn't referring to the op i quoted.
