Results 1 to 3 of 3
Thread: Fault 00135 Fuel/pressure low
    Jan 2012
    Help please. After almost breaking my GTI I am left with this code. My fault reader says it's the left front wheel acceleration sensor G337 but after research this description is not for my car but the code matches for a fuel pressure fault. I've cleared the code to see if it comes back. If it does what can I expect to be fixing or looking for. Car seems to drive well.
    Thanks again.
    Ozzy
    Edit. Forgot to add that I had a service yesterday and had the plugs oil/ filter and the fuel filter changed.
    2015 Golf R. Lapiz Blue.
    Jul 2005
    Nearly always get that code after changing a fuel filter,and they can drive a bit crappy in the first 100 metres until all the air is bled out.Clear the code and all will be fine. Happens most times when we do service with filter change on petrols and some diesels. Pete
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    Jan 2012
    Thanks mate. Feel reassured now, hate when I have issues. I'll let you know if anything changes.
    Ozzy
