Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Fan Problem
    Dec 2006
    Kilsyth, VIC
    I changed out most of the sensors before doing some major work on the AC system. The pressure switch on that ended up being the thing that solved my high speed fan issue.
    Oct 2014
    Quote Originally Posted by The_Hawk View Post
    I had the same thing after the front came off my car for piston work. Car sounds like it's about to take off into space. There's a switch or thermostat that's adjustable in there somewhere. It's only supposed to go nuts like that when you turn the car off and it's seriously hot. Shouldn't be a big deal to find and fix it.
    Can anyone point me in the right direction where the pressure switch is?
    Jul 2007
    Brissy
    Drivers side near/under the head light, next to the receiver drier.
    Has an electric connector on it should twist off a schrader valve.
    AC - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Thanks JustCruisn
    Quote Originally Posted by JustCruisn View Post
    Jan 2013
    Brisbane, QLD.
    Sure there is a TPI about this in relation to a S/W update...........
    Quote Originally Posted by The One View Post
    Might be showing my age here, but whats TPI?
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by richierichaudis3 View Post
    Technical Product Information
    It's basically a "service bulletin" about some fault or update or new procedure, etc.
    Can anyone tell me where are all the temp. sensors located in the TFSI engine/ Audis3 8p /Golf mkV1.
    OK......the problem with the fans was because of the thermostat. Took it to Prestige and Performance after changing the main fan and coolant to the engine block myself with no luck. They thought it was unusual showing no code errors and after a bit of investigating they said the thermostat needed replacing. Funny because that was the next thing i was going to change, but too much of a hassle.
