Originally Posted by
Large Fruit
How come you are going for an S3 intercooler and not for something bigger?
The S3 is sufficient for the car , with the addition of water - meth it would out perform any front mount available without the extra lag .
Ideo
17inch wheels won't work...
Whatever happened to the old 8L S3?
the 17inch wheel work with the brakes , I havent finished installing the brakes due to the caliper bracket not fitting correctly .
S3 is on the back burner until some other cars are finished .
Corey_R
Agreed. Given the amount of labour involved to take the entire front of the car off to change the intercooler, going to a S3 intercooler seems like a bit of a waste.
Swapping out the front mount is not the only thing I do to the front end when its all apart .
A waste is also something that you regret doing , I have no regrets going S3 front mount over a Eurojet/APR etc front mount .
KRA21E
I'm assuming the S3 cooler is being utilised because its lighter than a THS, Eurojet, APR and does what Seb needs it to do.
Btw Seb, I hope your jogging every night, thats the cheapest way to lighten the car!!
Thats exactly it , you dont want to add extra weight + engine lag on an engine part when its within spec of what you want it to do . Its like putting on bigger brakes on a track car and you have never experienced any brake fade . Its just creating more rotational mass that the engine has to move when accelerating that just slows acceleration down and you wont gain any advantage when you brake cause you never reached the potential of the old brakes !
As for me jogging , lol , I just build/test the cars . Courtney will be doing most of the driving , and yes she is doing all the jogging for me
Reason: Merged a quad post
Bug_racer supports the rebellion of the euro revolution
