Results 1 to 2 of 2
Thread: Error codes?? 103TDI
    Apr 2018
    Hey ,
    Just wondering if anyone knows whats going on with my 103TDI 2009 Golf, iv put the scan results below.
    I had two lights come on while I was driving on the freeway and I lost a majority of my power(struggling to reach 80km/h up a hill). Was like this for 2 days then suddenly the lights dissapeared and power was back completely??
    If anyone has any insight i would appreciate your thoughts, cheers.
    Error codes?? 103TDI-img_1054-jpgError codes?? 103TDI-img_1055-jpg
    Mack.
    Nov 2007
    NSW
    VAG Error Code: 18149/005953
    EOBD II Error Code: P1741
    Fault Location:
    Clutch Pressure Adaptation: Limit Reached - Lower Limit Exceeded/Upper Limit Exceeded
    Possible Cause:
    Possible Solutions:
    Check gearbox settings, Reset Values. 6-Speed Direct Shift Gearbox (DSG/02E)
    P0403/001027 - Exhaust Gas Recirculation (EGR) Valve (N1:
    Possible Symptoms Malfunction Indicator Light (MIL) ON Rough Idle Speed and/or Engine stalling Loss of Power
    Possible Causes Fuse(s) faulty Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve (N1 faultyExhaust Gas Recirculation (EGR) Valve (N1 stuck/faulty
    Possible Solutions Check Fuse(s)Check Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve (N1Check/Replace Exhaust Gas Recirculation (EGR) Valve (N1Check Measuring Value Blocks (MVB)
