Hey ,
Just wondering if anyone knows whats going on with my 103TDI 2009 Golf, iv put the scan results below.
I had two lights come on while I was driving on the freeway and I lost a majority of my power(struggling to reach 80km/h up a hill). Was like this for 2 days then suddenly the lights dissapeared and power was back completely??
If anyone has any insight i would appreciate your thoughts, cheers.
Mack.
VAG Error Code: 18149/005953
EOBD II Error Code: P1741
Fault Location:
Clutch Pressure Adaptation: Limit Reached - Lower Limit Exceeded/Upper Limit Exceeded
Possible Cause:
Possible Solutions:
Check gearbox settings, Reset Values. 6-Speed Direct Shift Gearbox (DSG/02E)
P0403/001027 - Exhaust Gas Recirculation (EGR) Valve (N1:
Possible Symptoms Malfunction Indicator Light (MIL) ON Rough Idle Speed and/or Engine stalling Loss of Power
Possible Causes Fuse(s) faulty Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve (N1faultyExhaust Gas Recirculation (EGR) Valve (N1
stuck/faulty
Possible Solutions Check Fuse(s)Check Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve (N1Check/Replace Exhaust Gas Recirculation (EGR) Valve (N1
Check Measuring Value Blocks (MVB)
