Results 1 to 6 of 6
Thread: EPC lights up the dash
    Sep 2009
    south australia
    Angry EPC lights up the dash
    Hi
    Almost home today when I lost power in the GTI and the dash light EPC came up , feels like its running on 3 cyl .
    Book says I should go asap to repair centre , maybe a coil pack ? .
    I am wondering is it ok to drive 10km to mechanic or should I get a flat bed .
    GTI clubsport/edition 40 manual white 2016
    Mercedes Benz A200 AMG pack red 2016
    Quote Originally Posted by spellbound View Post
    Hi
    Still got that TT?
    Pull the coilpacks out of the Golf and drop them in the TT one at a time. See if one has failed. If so, buy a coilpack and chuck it in. TT coilpacks wont go in the Golf unfortunately.
    Jul 2011
    Aust
    Hi
    Generally coil packs are ok until the engine is under load and higher in the rev range (but not always) However:
    Is it rough to idle? Try pulling one coil pack out at a time. The one that you pull and the idle doesn't get worse is your dead coil pack. I have four spare coil packs and located inner west of Sydney.
    To be clear.
    1. Turn engine off
    2. remove coil pack lead
    3. start car
    4 sound worse? replace lead and move to the next one
    ps - I keep a spare coil pack in the boot of the car. I did the same with my Audi as well
    Dec 2015
    Crafers, South Australia
    I found that once one coil pack went all 4 needed doing eventually. Get the latest ones, they seem to hold up better with all the heat under bonnet. Scared me the first time it happened, thought the engine was a goner!
    Sep 2009
    south australia
    Thumbs up
    Quote Originally Posted by Russ View Post
    Thanks Russ I will check that out seems odd since car has only done 34,000km , maybe stage 1 is a factor .
    Your right about scary , that little engine icon hit the dash first and thoughts of blown turbo or worse , than the EPC came up and I stopped pronto .
    Dec 2015
    My first one went at about the same km, stage 1 as well. I have a legend mechanic, he said rest would go, I only changed one. Sure enough 2 more went over the following 6 months so I just changed the 4th. After that it was all good until I sold it at 89000km, the newer ones are more resilient I believe.
