Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: EPC & ESP Lights on Golf R
  1. #21
    Jan 2011
    I agree with you Angryman, the VW dealer I was towed to is doing an excellent job, and have kindly provided me with a loan car so I could not expect anymore from them.
    I just wanted to lodge it with VW to ensure they continue to prioritise this as much as possible.
  2. #22
    May 2010
    Angryman, the guy didn't say he got stuck into them. For him to be getting this level of service, he must be being reasonable at this point.
    And why wouldn't you say "my car broke down after a couple weeks - and I have the ****s". It did. Just don't go on about it.
    Anyways, good to see they are dealing with it and giving you a loan car and NEW motor!!
    Who was the other guy who waited a month just for an ECU to come over!?
    I'd say orkers is doing good.
    2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
    2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
  3. #23
    Jan 2011
    New Engine Question
    This may be a silly question, but how can I be sure that VW will fit the correct engine to my R?
    I have no reason to doubt this for a second, but I'm obviously keen to ensure that the car I get back is the car I paid for. So, the questions I have are:
    a) is it even technically possible for them to put in an incorrect engine (for example the GTI engine)?
    b) If the answer is yes to the above, is there an easy way to check I have the correct one?
    Probably stupid questions but.....
  4. #24
    Nov 2009
    Rest assured, you'll get the right engine. Aside from the appearance, mount points, ancillaries etc etc all ensuring it'd be immediately obvious if something was amiss, the process will be driven by specific part numbers, which will ensure that what's ordered is supplied. You'd be concerned if your dealer's VW techs weren't able to tell the right parts from the wrong ones in this case.
    Given the extensive differences between the drivelines and electronic components of the R and GTI, I'm guessing a GTI ECU would probably not be able to run a car with an R AWD system... the two models do use different physical ECUs, aside from the coding differences.
    And after all that... I would expect there'd be physical complications - to say the least - involved in swapping the R's EA113 for something (anything) else, but I'm just guessing here.
  5. #25
    May 2009
    Quote Originally Posted by orkers View Post
    It will be a blessing in disguise if you did get the EA113 engine instead of the EA888 - but I'd say it would be neigh impossible that a mix up of this sort would occur.
  6. #26
    Nov 2009
    Quote Originally Posted by triode12 View Post
    He has an R. The EA113 comes standard.
  7. #27
    May 2009
    Quote Originally Posted by AdamD View Post
    Ah - didn't follow the entire post properly- lets pray he doesn't get the wrong engine. eeks!
  8. #28
    Jan 2011
    Thanks Guys, doesn't sound like I have anything to worry about then.
    Hoping to get the car back on Friday or Saturday. Can't wait.
  9. #29
    Good Luck! hope you get ur R back soon, such a painful story to hear about, esp with a new car, *fingers crossed*
  10. #30
    Nov 2010
    Maroochydore
    Further update to my Golf R woes:
    VW identified traces of metal in the oil, indicating that when the turbo blew it has caused further damage through the engine. Therefore they are now replacing the entire engine assembly.
    ETA is approximately 2 weeks due to the time it will take to get the engine in and then fit it.
    I just hope it'll be back to normal once done.
    VW Customer Service has acknowledged my complaint and are gathering the technical information around the fault.
    Since you're going to be there, good time to put in 2nd intercooler, fuel pump and cat-back....
    Black 3dr, DSG, ACC, 19" Black Talladega's, Heaps of Goodies - Double Tint - APR Stage 1 - Delivered and Lovin' my R
