Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Engine temperature 103TDI slow warming up and fluctuating once warm!
    Jul 2009
    QLD
    My mechanic changed the thermostat, once warm the temperature is now steady 90 deg, getting to the thermostat in the diesel is no mean task 4 hours labour plus parts original thermostat $92.65, seal $9.80, Coolant and consumables $50.00, labour $450.00 not cheap. Once I would have done this job myself but don't have the facility unfortunately. Still seems to take a long time warming up around 20 minutes to 90 deg in slow city driving, weather cooling now so perhaps normal.
    If anyone else has a MK VI 103 TDI I would welcome feedback on cold start to 90 deg, my brother has a MK V 103 TDI his is at 90 deg after 12 minutes.
    2017 MY18 Golf R Wolfsburg | Oryx White | DSG / 2021 MY21 T-Cross Style | S+V Package | Limestone Grey
    Jan 2010
    Condell Park, NSW
    Quote Originally Posted by rosslm View Post
    Will have to pay attention to mine... Bear in mind the water temp will take longer to get to 90º in cold weather and when the heater is on too..
    - Anthony.
    VW Tiguan 110TSI Life | Tungsten Silver
    Apr 2011
    Quote Originally Posted by hoi polloi View Post
    Is the display of the Oil Temp enabled?
    On mine (MY 2010) go to "SETTINGS" using the arrow buttons on the steering wheel, select MFD DATA and then scroll down and make sure the items that you want displayed in the MFD are ticked (I've just selected them all)... Tick the Oil Temp selection using the OK button on the steering wheel..
    Items that aren't ticked get skipped (if that makes sense)...
    - Anthony.
    !definitely not in the settings menu. cheers for the idea though !
    Jul 2009
    QLD
    Quote Originally Posted by raygti View Post
    My car has Oil Temp included in the MFD, build week 45, 2009 if this helps.
    May 2006
    Adelaide South Australia
    Not a Mk6 Golf, but my '09 Tiguan has no mention of oil temp.[ in instrument display] in the owners manual dated 18.08.2008. Next years manual dated 7.04.2009 does.
    At one time I owned a Mk2 Golf GTI that included oil temp in display. In hot weather I looked at it frequently.
    Numerous Mk1 Golf diesels
    Aug 2008
    Our MkV GTI is showing similar symptoms, do we think that it will it be a major exercise like the diesel?
    MY19 Tiguan Highline R-Line
    Jul 2009
    QLD
    Not sure about MkV GTI get your mechanic to check it out, thermostats obviously like any working part will fail at some point. My car is going fine now temperature steady on 90 deg once warm. Just get original equipment I guess. My brother has a MkV 103TDI 200000K still has the original thermostat so I guess it's a bit hit and miss as to time to failure.
    Hello rosslm. I think I have the exact same issue with my 103tdi golf. Started happening a couple of months ago just after the 60 000km service. I have had the mechanic change the thermostat but the problem still remains. I'm guessing you have had no problems since?
    Jan 2011
    Strathalbyn, South Australia
    My 103TDI DSG with 140K on the clock has just begun to display the symptoms.
    Pity it did not happen at 120K when I had the DSG service, new timing belt and new water pump. Another 4+ hours work.
    A VW Golf is like a German art house film, laughing clowns and naked women fighting maddened crows. A Toyota Corolla is like a glass of tap water. Jeremy Clarkson
