Results 1 to 10 of 14
Thread: Engine oil change Golf VI 90TSI
    Aug 2009
    Carlton,Victoria
    G'day gents,
    I've been a member for a while, but very quiet.
    I've had my Golf since new '09, and it's been a real gem (touch wood !)
    I've run out of time to get the car serviced before heading out on a long drive, so I thought I'd change the oil and front brake pads myself, I used to be very handy in my youth, so skills shouldn't be an issue !!
    If this has been posted before I apologize.
    So I imagine that I will need about 4 Litres of oil (any recommendations)
    A new sump plug (does anyone know what size it is and if it's torx ?)
    A new oil filter (does this require a special tool ?)
    Any advice to do the job right ?
    For the brakes does anyone know the minimum disk thickness. It has done 90K and it's still on it's first brake pads in the front.
    Your help greatly appreciated
    VW happy
    Chugoa
    Chugoa
    Golf VI TSI
    Pacific Paradise QLD
    Any VW approved oil at Supercrap There is Castrol and Penrite oils that qualify under either 502/505 for petrol or 504.507 for both petrol and diesel Must have the APPROVED wording on the bottle .
    Buy a genuine filter at a dealer. also a sump plug it is about $4.50
    How far are you going to need to do brake pads.
    Dec 2008
    Sydney/Canberra
    Genuine oil filter is about $25. You'll need a filter claw, or strap to undo it.
    Sump plug, which you only need a 19mm spanner for, is $4.50.
    Budget about $80 for the oil. Easiest to get hold of is Penrite 5W30 Enviro+. Use a small funnel to pour it. The hole in the baffle under the rocker cover is tiny.
    Genuine discs are about $100ea, and the pads are about $120 for the set. New wear sensors, bolts, and clips are included in the kit.
    Also at 90,000, you'd be looking at doing an air filter $45, and a pollen filter $40. Brake fluid may also be due, depending on when it was done last.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Aug 2009
    Carlton,Victoria
    Great thanks.
    Chugoa
    Golf VI TSI
    Aug 2009
    Carlton,Victoria
    Great information thanks. Where is the pollen filter located ?? How often do spark plugs need doing ?
    Chugoa
    Golf VI TSI
    Dec 2008
    Sydney/Canberra
    Pollen filter is under/behind the glovebox.
    Plugs get done every 60K.
    '01 Beetle 2.0
    Aug 2009
    Carlton,Victoria
    Quote Originally Posted by Umai Naa!! View Post
    Thanks for that. I'll get the parts today and get to it on the weekend. Thanks everyone for your help. I might enjoy getting my hands dirty again.
    Is there a handy link where I can get service information per Km.
    Chugoa
    Golf VI TSI
    Perth, WA
    I got Repco's brand of pollen filter, compared to flimsy VW it's made a lot better. First time for everything, lol.
    MY11 GTI DSG - SII Bluefin, Empire Dump, Custom intake, Front strut brace
    01 Pathfinder -Cat back, SAFC, Intake, Lift and Muddies
    88 HR31 Coupe - lots
    08 FG XR6T - 380hp
    Aug 2009
    Carlton,Victoria
    Quote Originally Posted by Brett_J View Post
    What about the air filter ? Is that better to get original ?
    Chugoa
    Golf VI TSI
    Perth, WA
    Quote Originally Posted by Chugoa View Post
    Yeah when it comes to things like that, it is best, I'm usually a stickler for OEM, but I found the Pollen filter was a better product.
    Any other filters - go OEM.
    08 FG XR6T - 380hp
