This topic has been discussed in great depth already, do a search on Golf and engine oil and you will get all the answers you need. Also visit the maintenance section. Effectively, you need to use certain synthetic oils specificed by VW, which select commercially available oils are also compliant with. Use anything else, you will lose your car warranty from VW.
