Ok so was driving home car driving fine and engine light came on ...stumped I got home and checked oil...low...topped it up with two of those blue bottles vw give you and then..light still on! Took for a drive round a couple blocks...seemed fine...coil packs??? Decided to pump it a little from second and reached 120 with no hassle ..
Got me stumped![]()
MY11 GOLF GTI MK6 | CSG| DSG
APR Stage 1
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
^^agree here , best to have the ecu scanned rather than guessing. If in warranty you will be sorted. There is so many variables that can trigger the light, a read is the only way. Shouldn't be too much of an issue if there is no difference in drive.
Keep us posted
Jmac
Alba European
Hi guys
Problem fixed! There was a loose clamp*from my intake into the turbo that was causing the light to come on! On another note spoke to three vw service centres and nobody was even remotely interested in seeing me..even after told them I had engine light ontold me it would be a week before they could see me..even after I said u just need to tell me the error code
Another note will from mike Webber is a legend...he was happy enough for me to pop down and he scanned and fixed it with in 10 minutes..if only vw offered this kind of service
that's why he moved to a bigger workshop. excellent customer service!
if only vw service centres could provide the same level of customer service...
MINI Cooper S Clubman - FWD
