Results 1 to 2 of 2
Thread: End of Warranty concerns 118 TSI 09
    Jul 2012
    Exclamation End of Warranty concerns 118 TSI 09
    Hi guys,
    Unfortunately my 118 TSI '09 Golfs three year manufacturer warranty is finishing up this week.
    I have been in touch with my dealership multiple times over the past two months to arrange a service prior to the warranty running out. Here's the problem:
    Dealership insisted that I book it in as close to the warranties expiration as possible as they run "diagnostics" to determine any faults. My vehicle has already had its entire engine replaced due to a sensor failing and the piston overheating and damaging? It also suffers from the supercharger squeal and my DSG shudders particularly in second gear and makes a terribly loud crackle / ticking noise when turning hard. If I take out an extended warranty they will not cover any existing faults, does this mean that VW is responsible for replacing / rectifying the issues as per a manufacturer’s warranty?
    At this stage I’m thinking about heading to VW Australia to see what they can do for me since I have campaigned from the beginning that I received a "lemon".
    Supercharger squeal:
    VW dealership identified it as a reported fault however no permanent fix was available (Oct 10)
    DSG Shudder
    A separate VW dealership had it for a week to investigate, put 1000 km's on the odometer and re-flashed the ECU - no change.
    DSG Crackle / Ticking
    Took a VW Mechanic for a test drive - he indicated that it was a "normal" sound and was probably due to the DSG changing gears.. I had the window down yesterday, full car of work mates, turned right and it happened - it was loud enough for everyone to comment on.
    I have been in discussions with the Dealer Principle of the VW dealership some time ago in regards to replacing / upgrading my "lemon" however he could not give me a good enough deal, still wanted to charge me 10k extra for a stock GTI even though I paid more for my optioned 118 TSI.
    Any advice would be appreciated as I dont want to be stuck with the costs of maintaining a faulty vehicle.
    Erskineville, NSW
    The existing faults should be covered as they were discovered / reported during the warranty period.
    I would confirm with the dealership what the actual end of warranty date was because when I took mine the warranty had finished 2 days earlier than what was expected.
    Have a chat to the contact at the dealer, then put all the resolutions & promises in a dot-pointed email & ask them to confirm within 48 hours & that no reply also indicated confirmation.
