What are the odds you've put a fuse back in the wrong spot?
Hey been a while but I recently did a long trip on the way back it was 40c the aircon stopped working so next servo I pulled up hoping it was a relay/fuse or something but after checking all fuses they seemed good but now my rearwiper cigarette lighter & aircon fan have stopped working. And its pretty hard to get a answer off Google what it could be. Plus I've lost the manual lol even though it doesn't neither do the covers tell you what fuses are for. It's a 2011 tsi 1.4 turbo golf thanks for any help you might give
90 TSI 1.4T
'07 Transporter 1.9 TDI
'01 Beetle 2.0
I posted a Mk6 golf electrical manual in the manuals and guidebooks section a while back. Maybe see if you can track the circuit using that. Also note that a one off problem like a short somewhere can screw up the body control module permanently. I had issues with the ceiling light shorting on a loose screw and a rear light shorting on water seepage. Problems were fixed but now my front left daylight running light is always chucking an error. Tracked it back to the BCM.
Thanks I'll check it out 😊
