Results 1 to 7 of 7
Thread: EDL vs XDL
    Jul 2009
    EDL vs XDL
    Anyone know what the difference is between EDL and XDL? I've tried researching on the net but have found nothing. I'm guessing XDL is a souped up version of EDL (but I can't even find anything on how EDL works to prove it).
    Skoda Octavia Mk3
    (sold) Golf Mark 6 Comfortline 118
    (sold) Golf Mark5 Comfortline Manual 2.0 FSI
    Jan 2008
    Quote Originally Posted by cktsi View Post
    Try the Golf GTI brochure on the Australian VW website.
    Electronic Diff erential Lock (EDL)
    This permits smooth accelerating on surfaces without uniform grip. If one
    wheel starts to spin, EDL brakes that wheel, directing power to the wheel with
    greater traction.
    Extended Electronic Diff erential
    Lock (XDL)
    XDL is an extension of the
    Electronic Differential Lock (EDL).
    This applies pressure to the inner
    front wheel during cornering to
    prevent spinning. Precise brake
    pressure helps to maximise traction,
    reduce understeer and improve
    responses, thus making cornering
    even more sporty, safe and accurate.
    EDL improves driving and steering characteristics when accelerating
    on road surfaces where each wheel has a different degree of traction.
    The system operates automatically and is combined with the ABS
    system. Using the ABS wheel sensors, EDL monitors the speed of the
    individual driving wheels. When a difference in driving wheel speed
    is detected (i.e. when one wheel starts to spin due to differences in
    road surfaces, e.g. due to water or dirt) the system brakes the spinning
    wheel, transferring engine power to the wheel with the best traction.
    Extended Electronic Diff erential Lock (XDL)
    The Electronic Differential Lock XDL is an extension to the EDL
    function. When cornering, the XDL responds to the unloading of
    the front wheel on the inside of the corner. The ESP hydraulics are
    used for the XDL to apply pressure to the wheel on the inside of the
    corner in order to prevent wheel spin. This improves traction and
    reduces the tendency to understeer. As a direct result of the one-sided
    and precise braking pressure, cornering is sportier, quicker and more
    accurate.
    Aug 2009
    Melbourne, Vic
    I think you might be right. They changed the coding a bit and declare they "fitted" an extended electronic diff lock.
    The GTI brochure whilst quite correct is of course a marketing tool and will have a degree of spin to it if you pardon the pun.
    The VW SSP Traction Control and Assist Systems (design and function) says this about EDL:
    EDL
    The electronic differential lock was originally designed as a starting aid. EDL intervention in the vehicle dynamics if one of the drive wheels is spins on accelerating. The spinning wheel is braked. Thanks to the brake’s specific intervention, the drive torque which can be transmitted at the spinning wheel is increased. The differential is able to transmit more torque to the gripping wheel on the drive axle. The vehicle accelerates faster and remains steerable. As the effect corresponds approximately to that of the mechanical differential lock, the system was called the electronic differential lock.
    EDL intervention can take place up to a speed of 80km/h (Touareg up to 120 km/h) and also during cornering. On actuation of the brake pedal or at maximum brake disc temperature, which is calculated by the ABS control unit, the EDL is deactivated immediately.
    I would like to know how they implement the changes that turn EDL into XDL. Is it simply a matter of changing certain parts of the ABS unit coding via VAGCOM as some of us have pondered?
    Jul 2009
    thanks mav. Since i have the 118tsi i never thought to look at the mk6 gti marketing brochure.
    Both of your explanations then raise the question of whether the anti slip regulator is also brake operated? I originally thought ASR was achieved by torque limiting somewhere in the drive train.
    In sydney's recent rain i have triggered asr and noticed its more 'violent' than my old mk5 2fsi manual. Dont know if its down to different gear box type or different implementation? Thoughts?
    Skoda Octavia Mk3
    Feb 2010
    NSW
    all this to avoid putting in a real mechanical LSD
    the lengths these people go to (not singling out VW, everyone does it)
    Sep 2009
    Quakers Hill, NSW
    Quote Originally Posted by TonyJZX View Post
    Interestingly, the Renaultsport Megane RS250 has electronic diff in the "sport" (softer) model, and mechanical in the "Cup".
    2009 118 TSI
    1980 Bedford van
    2015 Hyundai i30 SR
    Sep 2009
    Quakers Hill, NSW
    I have found it seems to depend on the available traction. On low grip surfaces like white lines, it seems quite violent, but on higher grip surfaces it appears gentler, just flashing the dash light.
    2009 118 TSI
    1980 Bedford van
    2015 Hyundai i30 SR
