Page 14 of 15 FirstFirst ... 412131415 LastLast
Results 131 to 140 of 146
Thread: Dynaudio in Mk6 Golf compared to stock?
  1. #131
    Nov 2009
    Quote Originally Posted by armpic View Post
    i think my dealer just put this by mistake. what should i do? let them know or wait till i pick up the car and point out the different from the contract and get some freebee...
    VW offers several Dynaudio systems across different models. In the Golf, it's the 300w Excite system. In the Passat CC, for example, it's an entirely different 600w system. Chances are the dealer just has a standard lineitem for a Dynaudio upgrade, which is a bit sloppy. I certainly don't think you'd get anywhere pressing the dealer for any concessions on it though.
  2. #132
    Jun 2012
    Brighton, Victoria
    Is the stereo upgrade worth $1500?
    Hi guys I've now got myself a Gold R with the stock sound system and with just over a week of driving, I'm not really that impressed with the sound quality of the stock system. While it has sufficient base, it lacks mid range and clarity which gives a nice 'warm' sound to each song. My previous car was a Mazda 3 SP23 with a stock 6 speaker Bose system which puts this to shame. What are the thoughts of people that have heard both the stock and upgrade? Is $1500 worth the upgrade? Is the stereo the same manufacturer, speaker size etc
  3. #133
    Nov 2010
    Burpengary, Queensland
    In my opinion, the VW Dynaudio option is not worth the money so I went this way
    http://www.vwwatercooled.org.au/foru...ics-71966.html
    If you don't want more bass, just go for the front splits and 1 amp. The Dynaudio I had fitted are brilliant, although not cheap.
  4. #134
    May 2011
    QLD
    I fitted my wife's Golf 77TSI with a Dynaudio Excite 252GT (shallower) and a JL Audio power amp
    I didn't know the non GT would work as well.
    BTW, there are line outs on the RCD510 so you can use a better external power amp?
  5. #135
    Nov 2010
    The amps I used are Arc Audio, a perfect fit under the seat. My RNS510 has no RCAs but they are not essential, just easier. The RCD510 that came fitted to my MY12 had no RCAs, so maybe you got lucky.
  6. #136
    May 2011
    QLD
    I didn't have an rcd510. Mine came with 310. So I swapped it out for an Alpine touchscreen satnav and reverse camera.
    So how did you hook your power amp up? Using speaker level?
  7. #137
    May 2011
    QLD
    Thing is the Dynaudio factory fitted has a Blaupunkt amp so there must be a way to tap into an external amp
  8. #138
    Nov 2010
    Mine had no external amp, unlike the MKV GTI I had. I didn't do the install, but yes amp hooked up via speaker outlet at HD
  9. #139
    Nov 2009
    Quote Originally Posted by TheMilkman View Post
    I've merged your thread with the existing one on the Dynaudio system.
    Lots of opinions on it. The most common seems to be that it's excellent value for $1500, but obviously you can do better if you go aftermarket (and spend a lot more). I love the Dynaudio in my Golf.
  10. #140
    Nov 2010
    A subjective topic, so long as you like it, that's all that matters. eg I like cats
