Sydney to Bathurst Drive:
Interested to see how the Volkswagen genuine lowering OEM Driver Gear Sport Springs fared on a very ordinary predominately B-grade road drive with extended time in the saddle. The drive from Sydney to Bathurst for the Bathurst 12 hour endurance race qualifying is about 220km one-way, which takes about 3 hours to complete for a total drive of 440km and 6 hours return route. It’s a mix of city – freeway for the exit from Sydney metro, then majority B’grade country single-lane roadway with a surface dishing up predominantly low and med speed compression hits to the Golf GTI suspension. The surface from the Sydney’s Blue Mountains to Mount Panorama is quite bumpy. The Sydney to Bathurst route entails the use of all three Dynamic Chassis Control (DCC) modes during different parts of the route:
Normal DCC in the City and for a third of the rural B-grade road route.
Comfort DCC for about a third of the time on rough B-grade country only routes.
Sport DCC mode for the Blue Mountains twisting hill-climb and descent and freeway cruising.
  • The Volkswagen Driver Gear (DG) Sport springs do a splendid job of improving the low speed compression ride reducing the small incessant vertical chassis movements. The original Golf GTI wasn’t so good in low speed small-bump ride compliance on this route and felt like it sat a tad bit too high for ride height esp. at the front end.
  • The DG Sport springs made for a terser ride on the slightly larger small bumps up to medium sized compression bumps, with the DG Sport GTI bucking and dipping to a greater extent with greater chassis control than the original Golf GTI. In this respect the DG Sport has traded off mid-speed medium -bump ride comfort for an improvement in small-bump low speed compression ride comfort. Depends on whether you’re looking for a knobbly & fidgety low speed compression ride with some steering wheel nervousness inherent in with the original GTI springs ... or ... terser and nuggetty mid-size bump ride and compliance of the DG Sport springs.
  • It’s worth noting that all three modes used in with the original Golf GTI springs at particular points in the Bathurst drive were also required to be used with the DG Sport Springs. The improvement or degradation in ride comfort & compliance has not changed a great deal with the change in springs.
  • Overall the ride comfort of the DG Sport Springs –v- Original GTI Spring is no better or worse imo. Each is better in some areas to the detriment of another area and vice versa.
  • The DG Sport springs have not eliminated the steering kickback that happens only occasionally on mid-corners bumps and corrugations of decent size. The kickback is more pronounced in Sport mode, as was the case with the original GTI springs. The MKV Golf GTI did not have this issue.
  • Urban intersection junction ruts, water channels and driveway lips definitely feel firmer than the original GTI springs as pointed out by my passenger that occasionally rides with me on day trips.
  • My infrequent passenger on the day couldn’t notice a great deal of difference between the DG Sport Springs and original GTI springs for ride comfort or compliance.
  • My passenger and I did not tire of the DG Sport spring 3 hour drives in the morning or late afternoon. This is a good sign for longer extended interstate drives of 10 hours +. This is also the case with the steering that is not overly direct with DG Sport Springs. I can rest assured that the DG Sport springs ride will not drive me bonkers on long interstate trips.
  • Ride Comfort in Normal and Comfort DCC was still good enough on the not so good B’grade roadways for my passenger to have a snooze. When it’s time to wake him up – just hit the Sport button to give a jolt or two.
  • The DG Sport springs definitely offered an improved ride over the KW V3 coilovers on softer settings for country road driving. Remember, that the KW V3 are able to go up to 20% softer than the KW V1 or KW V2 and generally ride country roadways better than the equivalent Bilstein and H&R coilovers.
  • 1-2 occupants in the DG Sport sprung GTI has it well & truly sitting perfectly for ride height imo.
On a side note:
Always good to include pics with each write-up. I’m sure you’ve seen enough pics of my GTI. Here are some pics of some more exotic metal. Just for R-Nick in Singapore running the Ohlins DFV / Driver Gear Sport combo on his GTI – Lamborghini race cars were also running Ohlins suspension. Have pics to prove so ... just take a look. Bathurst 12 hr race/qualifying well worth the 3 hour drive from Sydney. A lot cheaper for tickets than V8 Supercars, you’re able to get right into the pits, workshops and on-top of the pit-straight building for no extra charge – in addition to seeing an array of cars – 4cyl, 6cyl Boxer, V8, V10, 6cyl turbo and V12. Much more entertaining than just seeing a whole bunch of similar built V8 stock cars with different out skins.
See pics here: WHITE JAMES: Suspension & Wheel Reviews - Page 21 - VW GTI Forum / VW Rabbit Forum / VW R32 Forum / VW Golf Forum - Golfmkv.com
