Page 32 of 39 FirstFirst ... 223031323334 ... LastLast
Results 311 to 320 of 389
Thread: Dynamic / Adaptive chassis control (DCC / ACC)
  1. #311
    Feb 2009
    Sydney, Australia
    The steering weight of a non-ACC car is the same as an ACC car in normal/comfort.
  2. #312
    May 2011
    NSW
    Does anyone know of a way to modify the settings of the adaptive chassis control?
    I love the steering weighting and especially the throttle response of the sport setting, but don’t want to put up with the harsh ride on the bad roads in Sydney.
    I can do nice heel toe changes in sport mode easily, but can’t do the same when in comfort or normal – the difference in the accelerator sensitivity is quite noticeable. Toe on the brake, roll my heel onto the accelerator to give it a jab and nothing happens, unless I keep my heel there for some time.
    As opposed to sport mode – the revs go up nicely and immediately as soon as my heel touches the accelerator.
    Is there a way to adjust the system so that the sport setting for the steering weighting and throttle response is also applied for the comfort & normal modes? Ie only the damper settings will change between the 3 modes?
    MY12 Mk6 5 Door GTI | Carbon Steel | Manual | Leather | Adaptive Chassis Control | Bluetooth | MDI | Tint |
  3. #313
    Nov 2009
    Hills District, Sydney, NSW
    There has been some conversation about the mode affecting the actual drive, I read somewhere that it affects the dampers but also activates the AWD and removes the bias. Wasnt aware that the acceleration was affected
  4. #314
    May 2011
    NSW
    Quote Originally Posted by SilvrFoxX View Post
    This article from the VW UK website confirms the throttle response and mapping is also affected.
    Experience : Golf GTI : Volkswagen UK
  5. #315
    Nov 2009
    welll there you go.. the ACC option provides you with free sprintbooster
    Then to answer your question.. no I dont think anyone has thought of how to address this but for roughly 300 dollars you can buy a Sprintbooster which will allow you to modify the acceleration but thats about it
  6. #316
    Apr 2011
    Eastern suburbs, Victoria
    All this info is interesting. I never looked into all these changes that occur. Now I'll have to pay more attention when I change the settings.
    Golf R, Rising Blue, 5 Door, DSG and some extra fruit.
    Viagra on 4 wheels !!
    "If you can't fix it with a hammer then it must be an electrical problem"
  7. #317
    May 2011
    NSW
    Thanks SilvrfoxX, I had to google it to find out what a sprintbooster is - never heard of it before.
    Rob_R, you probably won't notice it in your DSG - the computer probably compensates for this. I doubt they would slow down the DSG throttle "blips" on purpose during downshifts when in normal or comfort.
  8. #318
    Sep 2010
    Melb
    Quote Originally Posted by slam View Post
    It does feel like a slightly different car though switching from Comfort to Normal. Those are the two modes I've tried most - I guess I just have to try the Sport one soon!
    Golf R 5 door United Grey | DSG | ACC | Leather | Bluetooth | 19" Talladega Black
  9. #319
    Mar 2008
    Canning Vale, WA
    I thought it was only the steering and suspension that changed on Sport.
    Now that I know throttle response also changes, I might have to use it more often!
    Good find.
    T Go
    MY11.5 Golf GTI | Bluefin Stage 2 | Pipercross Stage 2 Intake Pipe | AFE Pro 5R Filter | SPM Downpipe | VWR Sport Springs | H&R 22mm RSB | R LED Tail Lights
  10. #320
    Mar 2008
    Canning Vale, WA
    Just a quick one (maybe for the tuning forum not piggy backed on this one??)
    I am getting a bluefin unit for my car, and was wondering if people knew if ACC affected this?
    From the VW UK link above:
    Should the driver select 'Sport' mode the steering assistance is reduced, the damping is hardened and the throttle responses are sharpened as the mapping changes
    So if ACC/DCC is set to Sport, is it just the throttle response thats increased? or is there a change in the fuel map? Does getting the car's ECU Flashed affect this?
    I'm sure its probably not an issue, but just thought about it due to the situation.
    T Go
