Page 6 of 39 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 389
Thread: Dynamic / Adaptive chassis control (DCC / ACC)
  1. #51
    Sep 2009
    Perth, WA
    Quote Originally Posted by gtimal View Post
    Hi M
    Which model Potenza are they .I have the RE001 fitted on my current car and they don't suffer from scolloping like the old G3's .
    They are RE050A.
    GTI MKVI Candy White | 5 door | DSG | ACC | 18" Detroits | Leather | Electric Seat | Sunroof | RNS510 | Dynaudio | Park Assist | RVC | MDI
  2. #52
    Nov 2007
    Quote Originally Posted by MurphyTheElf View Post
    They are RE050A.
    Thank God. The RE001's on my MkV are garbage in the dry and dangerous in the wet. Previously had Yokohama Advan Sport V103 and CSC2s, and I've heard the RE050A is up there with those 2 performance-wise.
  3. #53
    Jun 2009
    my-86.com
    could you have a car with acc an coilovers? or acc is instead of coilovers?
    Would i be better off not getting ACC an just buy a decent set of coilovers?
  4. #54
    Dec 2009
    Well coilovers essentially replace your shocks and springs...
    And yes I would just go for coilovers if you plan on adding aftermarket wheels and dropping a little (or a lot).
    However if you plan to keep stock wheels, option ACC.
    2019 BMW M3 CS
  5. #55
    Jan 2010
    ACC or COILOVERS?
    im purchasing a brand new golf.
    im getting the 18 inch detroits.
    should i get the ACC with the car or should i purchase coilovers later on if i want stiffer dampers.
    the cost of ACC is almost same price as coilovers.
  6. #56
    Point Cook, Vic
    depends.
    ACC I would think is for those people that dont want to compromise on daily comfort. Other than that a set of coilovers will allow you to pick a rideheight/damper setting that suits your usage.
    For my personal taste id go with a good set of coilovers. But then i dont think its a decision that anyone else can make for you because it has to suit your set of requirements
    FOLLOW US ON FACEBOOK
  7. #57
    Jan 2009
    blankedy
    Depends if having the ACC on Sports mode is firm enough for you.
    VW's tend to have a soft ride, so I'd think if you want track handling, you need track suspension.
  8. #58
    Jan 2010
    well if i install ACC now, can i install coilovers later on? or there's gonna be alot of sensors dangling around?
  9. #59
    Dec 2009
    I went with the 18's and no ACC because I expect to change my suspension to a coil over setup down the track (not for the track).
    I think if you want the car stock ride height and wont change your wheels (but choose the optional 18's), you should pick up the ACC.
    2019 BMW M3 CS
  10. #60
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by alphabeatsco View Post
    This is a question I've yet to see anyone answer on these forums. I'm not sure that anyone here has bought a car with ACC on it and tried this.
    But I think that as Tim mentioned, it depends on YOU.
    The ACC allows you to press 'sport' for when you want that firm suspension and handling, and press 'comfort' for when you're on crappy roads or in a car park with 50,000 speed humps between you and the exit etc.
    Good coilovers are going to allow you to get better handling and fine tune the car the way you want. They're adjustable, but not DURING your drive. They would be far better on the track, and if you're a hoon, they'd be better on the road too
    But lets face it, good coilovers are going to cost you far more than the $1500 of ACC. From what I can see the Sachs Coilovers for the GTI are about RRP $3000 plus installation. KW Variant 3 coilovers are likely to be even more. (Kryten001 might be able to post here how much he paid for them to be installed on his Pirelli)
