Trade in Time: Golf GTI -v- Polo GTI?
It would be good if you could alter the steering resistance and damping using something like VAGCOM. Could be possible with the steering weight/resistance. Probably possible with the dampers with a pre-set incremental set of mathematical figures for damping force alteration. Extra damping in the mid-range would be good for the 30kph to 70kph speed range as imo the DCC Golf GTI could use a bit more compression and rebound in a straight line.
The Hydraulic aftermarket suspension systems like the Koni-FSD high frequency valve strut mono-tube or KW coilover offer a premium feeling ride over that of the OE Sachs Dynamic Chassis Control (DCC) damper. Ultimately it’s what’s inside that counts. The aftermarket hydraulic valved low/high speed compression/rebound units act faster than the electronics of the DCC imo as the fluid is pushing through a valve that works pretty much instantaneously, rather than having a computer turning a needle, etc in a fraction of a second.
Bear in mind that the difference between the DCC and non-DCC Mark 6 Golf R may not be as stark as that of the Golf GTI, where the Golf R has heavier steering & firmer suspension over the Golf GTI in non-DCC form. Having the non-DCC Golf GTI a little soft and the DCC equipped GTI more capable, but de-sensitised and lacking that ultimate raw driver appeal, may leave the new Polo GTI to offer up a tad more driver appeal. See video from Spain/Portugal:
Vw Polo GTI vs. VW Golf GTI DSG 2011 (English Subtitles) - YouTube
Video at the 4.15 min mark shows the Polo GTI to have more corner entry understeer and additional corner exit oversteer as was the case with the non-DCC Golf GTI around the Boat Shed run, albeit not as pronounced as that on the track or with torsion beam semi-independent rear axle on the Polo GTI offering up some bump steer.
The video does show a good visual representation of what I was feeling when driving the DCC –v- Non DCC Golf GTI’s. The Polo GTI does have a nice bit of oversteer at the 2.25 min mark – you’re not likely to experience much of that in my DCC equipped Golf GTI as it’s predominately a case of slight understeer right way through the corner in a very composed manner – surefooted and safe.
For a factory tuned hot hatch, I think you can’t go past the Renault Megane RS250 for driver satisfaction. Could use a tighter LSD for track work imo. Renault Sport seems to have the chassis dynamics pretty much spot on for driver appeal and liveability in the Megane RS250. The Renault Sport Clio Cup would be more fun, but perhaps a lot less liveable as a daily proposition with added suspension firmness and high revving motor – see link from South Africa magazine Driver Magazine.co.za.
Drive versus: Polo GTI meets Renault Clio RS 20th AE Part 3 | Drive Magazine
Cheers.
WJ
