Page 30 of 39 FirstFirst ... 202829303132 ... LastLast
Results 291 to 300 of 389
Thread: Dynamic / Adaptive chassis control (DCC / ACC)
  1. #291
    Nov 2009
    Quote Originally Posted by mr fox View Post
    My point....sports suspension is great, but for the long highway trips its going to be a life saver for someone like me with a crook back...having said that, its an option i put first on my list after driving a gti for a whole day in comfort mostly....
    I must be getting old and frail too lol cos that was my reasoning for getting it. Sport when the time suits, otherwise lazy old man for the rest Plus in my head I am hoping that the lazy lardy comfort mode will be enough to stop me driving like a total retard all the time!
    Quote Originally Posted by AdamD View Post
    I openly posed the question of ACC to the senior salesman at my dealership when placing my order; he advised against it (surprisingly strongly) as an option of little value that just adds to the depreciation hit.
    It is quite often very hard to make the choice on some options due to the lack of demo's available. I had the same issue with the race seats.
  2. #292
    Feb 2009
    It's not a bad option at all, I'd rate it more highly than leather and sunroof and is a pretty good price for what I is.
  3. #293
    Mar 2010
    Omnipresent
    This thread is tedious.
    LISTEN UP!
    If you live in Sydney or anywhere else that has crap roads ..... GET ACC .... it makes a big difference and is a cheap option considering that you will use it and appreciate EVERY time to drive.
    118TSI, DSG, Candy White, Sunroof, RCD510, Dynaudio, USB + iPod cable, Reversing Camera, Adaptive Chassis Control, Prem. Bluetooth, Fogs, Tint and Mats.
  4. #294
    Mar 2010
    Witness Protection
    My previous car had 17" wheels, but despite the 18" on the GTI, this old timer has found the ride to be very comfortable on NSW roads.
    Quote Originally Posted by dave- View Post
    But each to their own of course.
    Agreed. I think it is easily forgotten by those that have ACC that the standard GTI suspension set up is spot on, and oh so right.
  5. #295
    Feb 2009
    The previous suspension was quite under dampened on both the Mk5 GTI and R32 IMO.
  6. #296
    Jul 2010
    St Ives, NSW
    Quote Originally Posted by BBP View Post
    LISTEN UP!
    I guess it depends what you are used to. My current ride is an 04 Fiesta which is lowered and has 18's so the ride is considered by most who ride in it to be fairly firm. I've test driven an R with 19's and I can't say the ride was any appreciably harder than what I'm used to so am going without ACC.
    Golf R 5 door, DSG, EVOMS CAI, TXS DP, Recode Tune.
  7. #297
    Feb 2010
    Playing with the DCC settings on a section of roadway in northern NSW between Kempsey & Grafton, I had the opportunity to sample the speed of the DCC damping rates when striking a one-off large bump in both Comfort and Normal modes. Comfort mode had the dampers allowing the spring to hurriedly approach full compression until firming up and creating an almighty bounce upwards in the chassis, triggering the tyre indicator warning lamp.
    A second trip along the exact same roadway in ‘Normal’ mode DCC didn’t exhibit this tendency to almost bottom out and then firm up causing a mighty bounce upwards. In Normal mode DCC – the instant shock was correctly damped against the spring rate, limiting the springs from compressing too far before DCC having to apply much firmer damping rates to prevent the springs from hitting the bump stops on full compression.
    The Dynamic Chassis Control dampers are intuitive – but not instant as would be the case in a mechanical system as that found in a Koni – FSD damper for KW coilover that run varied rates of low-speed and high-speed damping compression rates. On the rare occasion, the Volkswagen electric motor Dynamic Chassis Control can be caught sleeping for that instant ¼ of a second – when in either extremes of Sport or Comfort settings – but much less likely the same scenario in the middle ‘Normal’ mode.
    The DCC does a great job of keeping the Golf flat in corners without the need to resort to large diameter aftermarket adjustable sway bars that will crap up the one wheel ride. Add EDL and XDS electronic diff and the Mark 6 Golf GTI is an easy vehicle for the driver to traverse the hinterland tight twisting roadways - much easier than the older MKV GTI.
    The DSG sport function on the Mark 6 GTI is nowhere near as aggressive as the DSG Sport function in the earlier MKV GTI – doesn’t hold onto the gears for what seems to be forever on the MKV GTI. You could even use it in town.
    WJ
  8. #298
    Jan 2008
    Quote Originally Posted by Maverick View Post
    I have a heap of information I'll be posting on my website in the next week.
    or few months..........
    Volkswagen DCC Adaptive Chassis Control - Design and Function
    Volkswagen DCC Adaptive Chassis Control - Technical
  9. #299
    Nov 2009
    Finally.... a thorough explanation of exactly what DCC is doing, without any guesswork or bullsheet.
    thanks Mav.
  10. #300
    I'm sure I've already +1'd somewhere in this thread before for DCC, but I'm gonna +2 now... I took my car for a quick spin down to Church Point in Sydney yesterday, twisty little road, not great quality. DCC set to Sport and let me +2,+3,+4, etc for DCC. You'd have to have rocks in your head not to get it if you plan to do anything but city/freeway driving. Completely changes the character of the car. In combination with those awesome S2TPP shifters, I'd swear that wasn't the car I commute to work in daily.
